Page 8 of 11 FirstFirst 1234567891011 LastLast
Results 71 to 80 of 107
Thread: BMW I-Bus How to connect..
  1. #71
    Registered User
    Aug 2004
    ok...quick question....is this iBUS plug-n-play? will the computer recognize it once it is plugged into the serial port?
    reason y i asked is because i just bought the iBUS thingie from germany and connected it to my car. Then, i connected it to my computer. How do i know my computer recognizes it?
  2. #72
    FLAC sama's Avatar
    Feb 2006
    London, UK
    use ibusanalyser and set it to the com port that your device is using (use device manager to see). Then you should see the messages of the car thru the ibus analyser.
  3. #73
    FLAC sama's Avatar
    Feb 2006
    London, UK
    does anyone have ibuscomm configured in such a way that it fools the car into thinking the CD player is always on?
  4. #74
    Mar 2006
    Im sort of new at this, but I got an e36 deck for my e30 that has I-Bus. I was originally going to hook my ipod up through the cd changer port. Would I-Bus allow me to plug my ipod in and control it through the deck?
    FLAC sama's Avatar
    Feb 2006
    London, UK
    I'm not sure how you've hooked up the E36 deck to the E30, but I would doubt that you have proper i-bus functionality. if anything, u probably have it from the headunit only. So in answer to your question, you would either need to search for an "bmw ibus ipod" and the likes see this: http://www.densionusa.com/icelink_info_bmw.htm or you have to find an ibus m-bus emulator. m-bus is the alipne cd changer standard. other manfacturers have different buses... hope that's enough to get you started on your quest!
  6. #76
    Mar 2006
    ok thanks! Yeah its just off the deck, I was thiking right after I posted theres probably more I am missing, I saw that ice link, I would rather not spend $300 on an adapter, I would like to try and make my own. Although that dosnt look very promising.
    Thanks for the help
  7. #77
    Mar 2006
    One more quick question. On my old kenwood deck I had in my other e30, it had an analog cd chager port, looke like a 8 pin DINconnector. I just looked up the schematics for it and found it was basically just a line in, I just had to jump two pins with a resistor to get it to click into AUX mode.
    Anyways, would it be possible with the BMW changer to do this at the very least? Just plug into the changer input line with an audio feed? I couldnt find schematics for this deck, but I would assume its a digital input.
  8. #78
    FLAC sama's Avatar
    Feb 2006
    London, UK
    no way it's digital, otherwise it would be the MOST system on the brand new bimmers. u ust gotta keep searching dude. try this:
    http://www.maushammer.com/systems/ip...od-remote.html
    there are many ways to do this, my guess is u'll need minimal electornics + switches (hack into a joystick perhaps?) and some cabling. good luck
  9. #79
    Mar 2006
    Alright, I will figure something out. I guess worst case theres an adapter from USA.SPEC for $110 that will allow my deck to control my ipod. Thanks again
  10. #80
    May 2006
    Dartford Kent
    Thanks for the info cdrskull, ive been wanting this mod big time!!
  1. Solved: USB bus stays powered after shutdown
    By S4Per in forum Power Supplies
    Last Post: 05-28-2007, 09:09 PM
  2. 03 BMW 330i Dinan S3 Project
    By fattytl in forum Show off your project
    Last Post: 09-27-2005, 10:24 PM
  3. Replies: 1
    Last Post: 07-28-2004, 10:26 AM
  4. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 02:16 AM
  5. BMW TFT Sharp LQ065T9BR52 - how to connect?
    Last Post: 05-31-2002, 09:59 AM
