You should be able to. It kind of also depends on the processor speed to. But with the board specs being able to handle anything between 550-933mhz for the P3, but with the celeron ranging from 333-500 you might have a problem with those. Even if it turns out that you are running a 333mhz celeron for example, the dvd decode cards are pretty cheap. Cheapest prices on pricewatch start at around $20.
LinkBack URL
About LinkBacks
