Results 1 to 3 of 3
Thread: Okay, Back to the Engine Noise
    Apr 2000
    Post Okay, Back to the Engine Noise
    Well, I hooked up my player. Everything seemed okay, except I heard a buzz at higher volumes. Checked my ground on the inverter -okay. Then I realized that I hadn't grounded my case. Went ahead and grounded the case, and voila, the buzz was completely gone. Only problem is, when I started the car a minor buzz had turned into major engine interference (whine). Anybody know why grounding the case would have turned a minor buzz into major engine noise and how to fix it?
    Thanks.
    Kevin
    Aug 1999
    Saint Joseph, MO, US
    Post
    Any car audio shop sells thingys to get rid of altenator whine.
    <A HREF="http://mp3mercury.ghettoware.net[/URL" TARGET=_blank>
    [URL=http://mp3mercury.mp3car.com]http://mp3mercury.mp3car.com</A>
    Apr 2000
    Post
    Problem solved.
    First, I ran the power line down one side of the car and moved the RCA line to the other. That helped a lot. Then I grounded the case to the same location as the inverter ground. No noticeable change there. Then I put in a ground loop isolator that I had bought a few days ago. Voila, no engine whine or buzz. The other day when I tried to use the ground loop isolator it caused extreme static - caused way more problems than it solved. I was ready to take it back to the store and as an afterthought tried it again this morning. I donít know what was going on the other day but there must have been a combination of problems going on which caused the GLI to make things worse.
    I've heard people naysay the isolators, but it certainly did the trick for me.
