Results 1 to 8 of 8
Thread: Fan control display
    Maximum Bitrate more mods's Avatar
    May 2003
    Atlanta, Ga.
    Fan control display
    Does anyone know where I could get a led display like these? I Dont care about the usb, fire wire and stuff, just a something to display temp., time stuff like that. Its really just eye candy. I would like one in my overhead console.
    Also what would happen if the temp. sensor wires were lengthened? Would it work correctly?
    Oh yeah, Those will not work cause the first is vertical (not that much room).
    The board on the other two is to wide to fit where I want to put it.
    Variable Bitrate no1knows's Avatar
    Feb 2004
    Guildford, Surrey, UK
    yeh you can lengthen them, check out coolermaster they do this sort of thing, i just bought the musketeer: http://www.coolermaster.com/index.ph...-U01+Musketeer
    Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
    Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
    CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
    http://www.no1knows.com/galleries/
    May 2003
    Atlanta, Ga.
    Quote Originally Posted by no1knows
    I'm not really looking for one that costly to cut up, plus the pcb is probably to wide because it has knobs. I need one with a small pcb and no knobs, usb, firewire ect.
    Feb 2004
    Jul 2004
    u might want to look into using a thermo couple and some of the LCDs that they make for the meters for this application....dunno what else you want to display other than temperature...
    May 2003
    Atlanta, Ga.
    I did google.
    But its hard to find pictures of the inside, to see how big the pcb is.
    I thought someone here may have seen one that has a small pcb.
    May 2003
    Atlanta, Ga.
    Quote Originally Posted by oekundar
    Thanks, I looked at them they are small, but not much for eye candy.
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    get a character LCD and do whatever you want!!! It is much better!!!
  1. Thermal Control Fan
    By cadence117 in forum General MP3Car Discussion
    Last Post: 06-16-2004, 04:27 PM
  2. AVS display control?
    By fondoo in forum MediaCar
    Last Post: 06-09-2004, 08:00 PM
  3. Replies: 3
    Last Post: 05-26-2004, 05:08 AM
  4. Replies: 22
    Last Post: 08-13-2001, 02:42 PM
  5. TI-86 calculator for control and display?
    By MacjediMatt in forum General Hardware Discussion
    Last Post: 07-04-2000, 12:50 AM
