Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: on the subject of HDD damage....
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    Post on the subject of HDD damage....
    this is on a hard drive sitting next to me
    "WARNING
    DELICATE EQUIPMENT HANDLE WITH CARE
    HEAD/DISC DAMAGE MAY OCCUR.
    PRODUCT WARRANTY WILL BE VOID IF LABEL
    OR TOP COVER IS REMOVED OR IF DRIVE
    EXPERIENCES SHOCK IN EXCESS OF 60 G'S"
    now, who was worried about shock?
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    I'M DEBT FREE!!
    I'm now a reasonably successful gunblogger.
    Jun 2000
    Salt Lake City, UT, USA
    Post
    So now,
    How big does the pothole have to be to reach 60G's?
    Hahahahaha!
    1983 BMW 733i
    Cyrix 166 32MB with MPXPLAY And no display. Player sits on the back seat with a keypad in front. Someday I'll mount this thing for good...
    Gathering parts for carplayer v2.0!
    Sep 1999
    Yarmouth NS, Canada
    Post
    A drop would exceed that, its just no sustained so it doesn't seem as strong as it really is.
    MP3 Cavalier - http://www.mp3cavalier.com
    MP3 Grand Prix - http://www.mp3gp.com
    Dec 1999
    Santa Ana, CA 92704
    Post
    I wonder if that's spinning or not..heh
    www.geocities.com/blkdragon6
    Oct 1999
    Oakville, Ontario, Canada
    Post
    Contrary to what you might think,
    the continual light vibration the hard drive experiences in the car is more likely to cause damage then dropping it once.
    But, I've had my HD in the car for almost a year now, no problems at all, and thats through 1 canadian winter as well.
    Oms
    Oms is offline
    May 2000
    The Netherlands
    Post
    Given a big enough pothole, I think you can get over 60 G's. Hell, back in Moscow I've hit potholes hard enough to bend a wheel rim. Drop something on a hard floor from 2' up, that's over 60 G's too. Remember, G is not how fast you go, G is how fast you stop.
    Custom Linux system on an '89 VW GTI 16V Edition One
    Jogdial volume control, Sony joystick, IR remote...
    Used to be the fastest Linux on the road, until all these NOS types came along...
    Bj
    Bj is offline
    Aug 2000
    Perth W.A Australia
    Post
    That's why you have to shock mount it. I have and it is the only way. My drive handled gravel roads without dramas, and even had someone run up the back of the car at 60km/h when I was doing 0. The car was recked, but the tunes kept cranking. That was 2 years ago. So boys I wouldn't really worry too much. If you take a little care in mounting it, you can't go wrong. Also don't wrap it on bubble wrap or similar, HDD die from heat more than shock. Use rubber gromets and it solves the heat problem as well as providing (I reckon) the best shock absorbing for HDDs.
    Just my experience
    Bj
    BjBlaster! Car MP3 & Carputer!
    bjblaster.com
    "The solution to one problem is only the beginning of another"
    Dec 1999
    Santa Ana, CA 92704
    Post
    currently I have mine mounted on four RC car plastic springs on the bottom, two strips of weather proofing foam on top and some padding on each sides to keep it from swaying side to side. I haven't had mine running for all that long, but I've gone over some bad potholes and various road vibrations with no problems. Keeping my fingers crossed.
    Aug 1999
    Upper Marlboro, MD 20772
    Post
    Its as simple as this.
    1) If it is not mounted correctly and i mean CORRECTLY it will DIE.
    2) If it is covered/wrapped in something, it will DIE.
    abcd-1
    abcd-1
    Dec 1999
    Santa Ana, CA 92704
    Post
    isn't the issue of weather or not covering the hard drive with some type of material a matter of how fast it's spinning? I know that overtime it won't matter how fast it's spinning and depend on how long it's been spinning, but wouldn't you have the same effects if your hard drive was stuffed into a small case with little to no circulation?
