You want Normally Open Pushbutton switch. Here is a link to what you may be looking for.
http://www.frozencpu.com/cgi-bin/fro...nu_search.html
From hibernate mode i wanna wire a switch from my laptop to my car consul. What is the best type of switch to do this. There are momentary, flip, or push-on / push-off switches. Im thinking push-on/off type but not positive.
Also does anyone know where to get nice glowing, or backlight switches??
Thanx a ton.
smonice
LAND ROVER DISCOVERY SE7 (85% done install)
Check out my hopefully useful site...
www.hobbybotics.com
It's still under design but it is functional
will this one work???
http://www.frozencpu.com/cgi-bin/fro...ml?id=4MnorP2s
(Green Illuminated Bulgin Vandal Switch -Ring Illumination)
couldnt really find one that said normally open pushbutton switch in teh specs.
smonice
well what you would realy probably want would be a momentary switch that closes the circut when pused. in my opinion it would probably be much easier and safer for your board if you use one that wasn't lighted. there is always your local ratshack
sagekoala: and tht will kick my laptop back on from hibernate and act just like the button that is there allready?
smonice
thanx a ton, i appreciate it a lot. hope this works.
smonice
www.hobbybotics.com
For the round LED rocker switches on that site... what kind of amperage can they handle? Could they be wired right up to a Xenarc, or would a relay be required? I'll assume they could handle the amperage for an amp remote wire.
95 Chevy G20 Vroom Boom Room
...with a whole bunch of nifty ****... go check it out: VanDomain Page
