Results 1 to 5 of 5
Thread: 3 Blink blinkers? How to?
    It's not really that small...No, seriously. judoGTI's Avatar
    Feb 2004
    Florida
    In Europe, some cars have an ability when the turn signal switch is depressed, but not locked into place, to blink 3 times and then stop. Used for switching lanes on the highway and what not. Kind of a momentary blink.
    Is there a way I can make something that will do this for my car? Where I would slight depress the turn signal level to activate the light, and then be able to let go and have them blink 3 times?
    ??? Electrical guru's please advise.
    '02 GTI
    [Routis '04] [Opus 90W] [160GB Maxtor HD]
    [Lilliput 7" TS] [VIA M10000] [XMPCR]
    [512MB RAM] [Custom housing]
    [Deluo GPS Mouse] [E-MU 0404 Soundcard]
    Progress Meter: [==============|] 99.9%
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    find a car that has it, and then nick the bits.
    j/king
    well actually find a car that does it, go down the scrappy and see if there are any there.
    Dec 2003
    Michigan
    You could use the turn signal switch to activate a 555 timer with enough up time to get your three blinks in (or however many you want) or something similar. You then connect the output of the 555 timer to a relay to the blinker. The issue you might run into is when you are actually turning, the blinker will most likely blink three times even after you have turned the blinker switch off.
    2006 Chevy Colorado: VIA M10000 EDEN, 1 GB RAM, 80 GB 2.5" Seagate HDD, USB Slim Slot DVD/RW, Holux GPS, MobileVU 10.4" LCD (touch not working yet), VOOMPC Case (blue), 70W DC-DC supply.
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    The major problem I see with doing this is that on most newer cars, the switch controlling the blinker does not directly connect to the light. They normally go through a BCM first that takes inputs from a range of devices then figures out what to do with those signals to turn them into commands for other devices. i.e. the hazards button, alarm, and turn signal control the blinkers on my car all going through the BCM first. You can do what your asking, but you will either lose this other functionality or have to bypass the BCM for the 3 blinks and only the 3 blinks and hope it doesnt mess with the other signals sent from the BCM.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Dec 2003
    Michigan
    The only thing to remember, is that when the blinker is on... you hear the blinker clicking. Thus, there is a blinker someplace that you can interface with and ignore the rest of the PCM connections.
  1. Parking brakes
    By Confused in forum Off Topic
    Last Post: 04-15-2004, 05:37 AM
