Results 1 to 6 of 6
Thread: Case Quesetion: Which one should I get?
    Low Bitrate Udonboy's Avatar
    Aug 2004
    Anaheim, CA
    Right now, I'm trying to figure out which case would be best for me to get.
    I would be placing the box underneath the seat on the driver's side. Here's a list of what I plan to put in it.
    Opus 90W
    VIA EPIA M10000
    Segate 40GB 5400 rpm
    512MB PC2100
    Toshiba Laptop Internal 8xDVD + 24x CD ROM
    I've been looking at the Casetronic C138 mini-ITX, but I was looking at some other smaller and cheaper cases. I like the Morex 3677, it looks sleek and it's small. But I have two questions with this one. 1) Will my PSU fit inside this box if I replace the 60W PSU that comes with it? and 2) Will heat be an issue? If it is, would drilling holes in the sides and possibly placing another fan inside be a good solution?
    Elsewhere
    Quote Originally Posted by Udonboy
    Opus 90W
    VIA EPIA M10000
    512MB PC2100
    Get the one that fits where you want to mount the PC in your car.
    The Opus power supply can be external to the case or can be removed from its housing (if you dare) to fit in smaller cases.
    You'd know that if you'd use the feature...
    How about the Wiki?
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    You should be able to squeeze an opus 90W into a C138 if you remove the existing power supply. The morex I don't believe will take a 3.5" HD.
    If a C137 will fit that'd be a good choice.
    Aug 2004
    Anaheim, CA
    Oh, I wasn't going to put a 3.5" HD in there anyways, that was a 2.5" HD.
    Fitment of the PSU in the Morex box was the minor one of my 2 questions. I'm more worried about heat. I knew I could just mount the PSU on the outside of the box, then I wouldn't have to worry about heat inside, but I would like to keep everything inside the box to make things look neat.
    Variable Bitrate LanoX's Avatar
    Aug 2004
    Sydney
    have a look at this case looks nice and small
    http://www.epiacenter.com/modules.ph...e&pid=8&page=2
    Aug 2004
    Atlanta Ga
    I have the morex 3677 with a p4 board in it. The 3677 has 2 fans mounted on the side and heat hasn't been a problem for the 3 weeks I've been running it.
    Not sure about size of the Opus 90w, the 3677 come with a 120w, but I removed it and now use an Opus 150 mounted externally.
  1. Replies: 97
    Last Post: 09-18-2006, 02:56 PM
  2. Remove my pc guts and put into smaller case
    By muldrick in forum General Hardware Discussion
    Last Post: 09-03-2006, 09:12 PM
  3. To case or not to case?
    By dummptyhummpty in forum General Hardware Discussion
    Last Post: 04-08-2004, 07:19 PM
  4. Need your input on custom case
    By Adam F in forum General Hardware Discussion
    Last Post: 09-24-2002, 10:42 PM
  5. Mounting the case
    By TheFly in forum General Hardware Discussion
    Last Post: 05-05-2002, 04:11 PM
