Results 1 to 6 of 6
Thread: Input signal for 6" Sharp LCD screens
    Nov 1999
    Sydney NSW Australia
    Post Input signal for 6" Sharp LCD screens
    Can any one tell me what type of signal does 6" Sharp LCD screens ( the ones from eio) takes.
    is it S video or NTSC video signal?
    And whats the really difference between those signals?
    thanx guys
    Fosgate
    Fosgate
    System Comp V3 - In progress.
    Low power MB with C7 CPU, DC-DC PSU, car ECU link, USB TV, GPS, 7" TFT, Wireless, Voice.
    Jan 2000
    Post
    The screen above takes an NTSC signal, like what you get when you have a vid card with tv-out on it.
    Venomous MP3!
    CarMP3 system:
    200mhz, 20gb hotswapable drive, 128mb, Winamp w/full-screen vizes, (upgrading to WinAmp3 in near future), 5" LCD screen, controled by numberpad, Sproggy PS under construction, custom mounting case under construction.
    pcman18
    Guest
    Post
    adder australia uses pal
    fosgate your gonna need to get a pal -> ntsc convertor or a vid card with ntsc out
    i sujest a vid card with ntsc out cause pal -> ntsc is really bad quality
    just my opinion
    ive got a ati vid card that my mate got from indonesia and its ntsc out and in which is a bummer cause i cant use it
    Nov 1999
    Post
    Ok thanx for the help guys.
    Fosgate
    Fosgate
    Dec 1999
    Buena Park, CA
    Smile
    To answer your other question (what is the diff between composite and s-video?) Composite is the lowest common connector for video. The signal carries all the information needed to draw the video image on the screen. The decoder card in the monitor has to do more work with a composite signal, and if teh quality isn't that great, then you will see artifacts, mostly dot crawl and chroma shift. S-video is the next step up the quality chain, and I would strongly recommend using it if it is available. Whereas a composite signal is a single channel, s-video uses two channels, one to carry the b&w info and one for the color info. This relieves the decoder card of the monitor and allows for better color reproduction.
    PAL is inherently better at color than NTSC, and has greater resolution, so wherever possible, you should have better results if you can get a PAL monitor. I believe most computer video cards allow you to select your output format (PAL, NTSC, SECAM).
    KG6OQD
    www.americansandassociation.org
    Variable Bitrate spud42's Avatar
    Oct 1999
    brisbane,qld,australia
    Lightbulb
    http://home1.gte.net/bs/sharp2.html
    fosgate check this site out... shows how to hook a matrox card to sharp lcd's
    Volvo V40 Phase 2 2002. T4 turbo upgrade.... currently no mp3 or carputer..... researching options
