Results 1 to 10 of 10
Thread: Help Needed
    Variable Bitrate LanoX's Avatar
    Aug 2004
    Sydney
    Help Needed
    Okay Kids nah joke Lady’s and Gent
    I need a little help i have been reading a lots on this forum and researching though and using but i still cant make up my mind 100% on what hardware i should get i am thinking on going micro ATX board or Mini-ITX boards not decided as of yet and i have no idea on rest of the parts as i have never used mini computers could someone help me out or do u think its better to go with normal computer ?
    thank you very much
    Variable Bitrate RS3RS's Avatar
    Aug 2004
    Springfield, MO
    It's all the same as a full sized ATX motherboard. The only thing different is the size. The Mini-ITX boards use less power too, but as far as building them and parts, it's all the same (with the exception that some of the VIA ITX boards have the processors built in instead of adding one on).
    If you need something that doesn't use much power, and can be squeezed into tight places, go mini-ITX. If you need something with lots of power to do stuff, and is in most cases a bit cheaper, go full sized.
    I personally prefer micro ATX, same thing as ATX just smaller.
    Aug 2004
    Sydney
    Quote Originally Posted by RS3RS
    tnx for that plz i would liek to hear some more suggestions before i go out and spend some money that i dont have lol
    Variable Bitrate Batmanatthenewb's Avatar
    Sep 2003
    Newark, Ohio
    LanoX,
    You have many options before you. as RS3RS said, it's all about the configuration and what you want your system to do. If its mainly for mp3 playing, than a smaller cpu is ok. If your going to be using gps, playing music and running outlook to get contact info all at once, you will need more power.
    I use a full size ATX raid board from MSI. By utilizing the raid setup, if your hard drive fails, you just make the other drive your primary and you are up and running with no data loss.
    If you are going to be primarily using usb as the connectivity for your peripherals, than either type of setup will work. Make sure you go with USB 2.0 though. If you want to use full size PCI cards, the microATX and an EPIA boards only have a couple of pci slots, where a bigger board gives you additional flexability.
    Some of the smaller boards have built in video. If at some time you want to upgrade, you won't be able to unless the have an AGP port.
    I may not be correct on this next statement, but if I remember correctly, the EPIA boards only have one or two pci slots. If you need to run more than two pci cards, you are in trouble.
    Some of the smaller boards (EPIA) have a different power supply than the bigger boards. As I've stated many times before, if you are on the road on vacation and your power supply goes out, where are you going to find a specialized power supply? Where as with a system that utilizes an inverter and standard power supply, you can find the parts anywhere.
    How much ram, and how many slots it has is important. Many of the people here are running smaller amounts of ram. This does not work for me as I use my system as a mobile office. Plus DVD's play back better with a higher amount of ram.
    That's about all I can think of for now. Hope this helps. Remember everyone has an opinion about the best setup. What you need to do is sit down and really decide what the most important features are to you. Then you can build the "right" system.
    Batman
    Aug 2004
    Sydney
    tnx for that batman can some 1 put little bit more responses and tell me what they think i should go with from personal experience Mini Comp or normal Desktop comp? thank you very much i am sorter pulling my lag at the moment more on the min carputer than desktop but as batman said if something goes wrong desktops are easily replaced than mini..
    but will have to decide in next 2 days .
    thank you all
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    I'm going to being using a Asus micro atx board, with a mobile athlon processor (see sig). It is the same as using a full size board, just smaller and minus a couple pci slots. Plus the mobile athlon runs much faster than any of the epia boards, and it ouly uses 45w, so you don't have to worry too much about power as opposed to a regular athlon.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Aug 2004
    Sydney
    Quote Originally Posted by Quattro-A4
    aha i see what case are u using for that ? and also do you know any good shops in Aust that you can get mini computer parts as i cant seem to find any );
    tnx
    Aug 2004
    Sydney
    can some 1 tell me whats good micro atx board for intel ? plz thank you ver much
    oh 1 more do u think Micro or mini boards are better tnx
    Dec 2003
    New York
    Quote Originally Posted by LanoX
    tnx
    I'm not going to be useing a case. I'm making a custom box/case to put everything. As for shops in Aust, can't help you there.
    Installed
    Constant Bitrate OdysseyPC's Avatar
    Oct 2003
    ACT, Australia
    Your best resource for computer parts in Oz is http://www.razorprices.com
    For mini-boards I would recommend EverythingLinux.com.au, EYO computers and Thunderbird computers ... I've dealt with all of them and they have proven to be good value for money.
    Hope this helps and good luck as you begin this magical journey
    Caputer Mk. II
    '02 VX Holden Commodore Series II Executive
    MII12000, 512MB RAM, 60GB HDD (5400rpm), 16X DVD, TS200V
    Morex 60W DC-DC, Custom S/SDC
    OS/Software: Developing...
  1. Stand-alone programs (no installation needed)
    By d_sellers1 in forum Software & Software Development
    Last Post: 07-19-2004, 07:45 AM
  2. Amplifier Needed?
    By c0rrupti0n in forum Newbie
    Last Post: 03-15-2004, 03:04 AM
  3. Connect 3,5' hard drive in place of 2,5'' (dcdc for 12v needed)
    By FedorComander in forum Power Supplies
    Last Post: 11-04-2003, 07:16 AM
  4. My project for the day - advice needed
    By ddt in forum General MP3Car Discussion
    Last Post: 12-02-2002, 07:51 AM
  5. 12volt Regulated Supply help needed.
    By Genesis in forum Power Supplies
    Last Post: 01-16-2002, 09:01 AM
