Results 1 to 3 of 3
Thread: Starting XWindows w/o Loggin In, Can it be Done???
    Jan 2000
    Question Starting XWindows w/o Loggin In, Can it be Done???
    OK this may sound like a really wierd question but I want to know if there is a way to boot linux and start XWindows ( Gnome, KDE or Enlightenment ) without actually logging in. My idea is there is some great software written for linux that would work great in a Car environment such as Mp3 Server Box but I can't get through the login. Any ideas around this, everyone I talk to says theres no way. Anything would be greatly appreciated. Thanks in advance.
    Jan 2000
    Well, you could always have it boot into single user mode (edit inittab for that) and have "startx" run on startup.....
    Venomous MP3!
    CarMP3 system:
    200mhz, 20gb hotswapable drive, 128mb, Winamp w/full-screen vizes, (upgrading to WinAmp3 in near future), 5" LCD screen, controled by numberpad, Sproggy PS under construction, custom mounting case under construction.
    Apr 2000
    The best way is this:
    Setup an account and make sure it has NO password set.
    Then edit your /etc/inittab so you can edit the agetty process on your first virtual console. (You will also want to make sure you start in the multiuser console runlevel, NOT the x runlevel)
    the agetty usually runs login which asks for user/pass.
    If you add the -l option to agetty, you can specify what login program to run and options to pass. Then we can tell login what username to assume.
    agetty (normal options that exist now) -l '/bin/login username'
    OR if you want to use the root user, just add -n after agetty. -n forces login to run as root and not prompt for user/pass (and is less typing)
    if you need a nonroot user, you will have to use the -l option above.
    THen edit that user account's .profile so that
    if [$TTY == tty1]; do
    This way using the virtual console you setup with no pass, it forces X to start.
    any other virtual console (or network) will Not start x and will login as normal.
    With this it should start the sys, login as whatever user, and start x, all without asking for a user/pass.
    This is the method i use.
    I also use root login as my xwin shell i made does not allow easy interaction with anything but it.. and there is no mouse/keyboard (its all touch screen) so security is not an issue.
