Results 1 to 10 of 10
Thread: Laptop vs MINI ITX PC
    Aug 2004
    Wink Laptop vs MINI ITX PC
    Hi all. Just wanted to hear some opinions about the advantage of using MII 10000 board vs a regular IBM Thinkpad (lets say... t22). You can get a used T22 on eBay for about... 300-400 dollars. You WILL spend much more money building a custom computer and from what I understand P III 900 (in T22) will outperform VIA Processor.
    Jul 2004
    Well that wouldn't be very fun...
    Aug 2004
    Germany
    I just bought a Lifebook B2562 it has a 10.4" Touchscreen so you dont need a expensive liliput the display supports 1024x768 it has a 700Mhz PIII 256MB Ram and 20GB HDD so that is quite enaugh for a car pc and you can not only use it in car :P i hope ill recive the notebook tomorrow so i could tell you more then. I only have tu build my custum car holding .
    Golf 3 CarPc Status
    ///////////////50%--------------/
    PSU:Inverter
    GPS:BT GPS
    PC: Slim notebook with 10.4"touch, external DVD.
    Dock for car is in production.
    Audio: Stock speakers but looking for new ones. CD-HU with FM modulator (ordered)
    Aug 2004
    Well... I have Thinkpad T23 in my trunk but I am still using Lilliput. First of all it is much brighter then regular LCD panel and it just looks SOOOO much better in my car
    FLAC ppgt94's Avatar
    May 2001
    USA
    Quote Originally Posted by erazor
    I don't mean to be a "hater" but what fun is that? How do you plan to intergrate into your car audio? I can't image that "holder" and wires hanging everywhere are going to look very good.
    Aug 2004
    Germany
    ill tell you how i use it i only have to plug in 1 USB wich is connected to a hub wich is connected to USB-Sound USB-GPS and the power and serial ports are in the dock wich is permantly monted to the dock :P
    Golf 3 CarPc Status
    PSU:Inverter
    GPS:BT GPS
    Maximum Bitrate zPilott's Avatar
    Jul 2004
    Austin
    The main reason that I would change my setup (a laptop) is that you are pretty much stuck with what comes with it, at least for video. The video card in my laptop is crap, and I REALLY dont like having everythign streched in windows (powerstrp doesn't support the video card). I am also getting some noise (fairly minor) from the HDD that I can't seem to get rid of, even with an external soundcard, though I don't know if this is specifically related to the laptop
    I have a laptop with a broken screen, so it is (going to be, when I figure out how to do it) permanently mounted and hidden from view. I opened up the case and I have wire connected to the screen sensor and the power switch, giving me a lot of options for controlling startup/shutdown/suspend/hibernate.
    Because it runs off an internal battery, I dont have to worry about cranking issues. Laptops are generally designed with lower power components, though I have no idea what the difference in power draw is. Depending on the computer, you can get dc-dc power supplys fairly cheaply.
    Aug 2004
    i just bought a tablet PC off ebay
    fujitsu stylistic 3500
    hopefully it will work well as both a car computer and for a scribble pad for taking notes at university
    500mhz celeron 192mb ram 15gb HDD win2k 10.4inch touchscreen
    hopefully it all works out
    Sep 2003
    I was looking for a tablet pc too and fujitsu stylistic 3500 sounds good. What about the "sound" output, have u ever try to play DVD/DIVX on it? What about the pen?
    Maximum Bitrate GingerPrince's Avatar
    Apr 2003
    Leeds, UK
    My last carputer was an EPIA/Opus configuration which was great. My new one however will be a laptop.
    I think that the EPIA/Opus solution is superior, more flexible, and more fun. However my new car is notorious for eating battery, so I don't want to risk draining it further. Also the boot (trunk) is so small that I don't have space for a secondary battery to aleviate this.
    So, a laptop with port replicator and lilliput up front it is. Just need to get me a laptop now.
    GingerPrince
    Car changed for TVR Griffith 500, so computer de-installed. Using a Dension 100ix w/60Gb HD unit in the interim.
    Carputer Install - http://www.stuffandting.com/carputer/
    CarBox Software -- http://www.stuffandting.com/carbox/
  1. Cant put two pc cards in my laptop
    By vipergda in forum General Hardware Discussion
    Last Post: 06-12-2004, 01:47 PM
  2. Mini ITX MB? HELP
    By fondoo in forum General Hardware Discussion
    Last Post: 05-06-2004, 08:46 PM
  3. Newbie asks ? Laptop based carputer vs desktop pc based carputer
    By SAScooby in forum General Hardware Discussion
    Last Post: 03-01-2004, 01:59 PM
  4. Opus and Casetronics C-134 Mini ITX
    By millec in forum General Hardware Discussion
    Last Post: 06-24-2003, 12:31 AM
  5. Did anyone buy the Mini PC
    By Starman in forum General Hardware Discussion
    Last Post: 01-10-2001, 06:09 PM
