Results 1 to 7 of 7
Thread: MP3's on a 486?
    Apr 2000
    Manhattan
    Question MP3's on a 486?
    I was wondering if anyone out there had any experiance running mp3's on a windows 95 computer with a 486 processor. If so, what do you think are the minimum specs for processor speed, memory, etc. and how well does it work (ie. not stuttery) Thank you in advance.
    Apr 2000
    il
    Post
    dos and mpxplay work on an amd 5x86 133.
    havent tryed linux yet.
    dont wast your time trying with 95
    Oct 1999
    Yukon, ok , USA
    Post
    I think most mp3 decoders take a pentium to work right. With 95 in the way I don't know. I have an lp3music device that will work all the way down to the 386 level. Even at $99 USD I have found it to be a worthy investment.
    Apr 2000
    Post
    A 486 dx 66mhz is about the min you would want, as in linux i have used this setup before without problems. 33mhz just wont cut it right, unless you always bump the quality down to like 8k.
    ive never tried a 40mhz 486, but i would just assume it would be closer to 33 than 66...
    I would also assume DOS is just as system friendly as linux when it comes to CPU speed.
    Dont use windows however.
    A p75 (75mhz) with win can chop mp3s badly, so youd need atleast a p133 for it..
    Apr 2000
    Manhattan
    Post
    My plan had been to use a device I found on ebay. I can't remember the name but if you do a search for "pen computer" you'll find several similar devices. Tablet like computers with built in CD-rom, screen, etc. running on a 486 50mhz. A second thought would be to use one of these as a remote display/input console for my laptop (PII-233). Let me know if you have any ideas on how this might work.
    Aug 1999
    Gorizia, Italy
    Post
    I tried to play mp3s on my 486dx266 @ 80mhz, but with no luck.
    I used both dos and linux players, with all the slow computers optimizations turned on. The music skipped every 4 secs.
    I think a 486 dx4 100 will almost do the job.
    Lorty
    <a href=http://lorty.mp3car.com/> lorty.mp3car.com </a>
    May 2000
    Guadalajara, Jalisco, Mexico
    Post
    I tried with a Texas Instrument 486dx4 -100Mhz with mpxplay, it doesn't cut it. The author of mpxplay says that with a true intel 486 it does it. I dropped a Kingston CPU replacement (Cyrix 586 @133Mhz) and then mpxplay had room to play (55% CPU use with a 160K mp3 stereo). With that machine, under win98 (98lite applied) the same mp3 ates 86%, just enough for the palmamp plugin.
