Results 1 to 5 of 5
Thread: digital voltmeter = interference??
    Question digital voltmeter = interference??
    I just installed a digital voltmeter, i ran the +12 volt down the passenger side, away from any wires, and grounded it to a bolt on the chassis, and the +12 volt switched source is the same as the head unit switched source. Anyways, i have a single 12" and i am getting buzzing in it now that I installed the voltmeter. I disconnected the ground, and the interference stopped...so I think this may be the source, but I'm not sure. I have tried multiple grounding points to get rid of the interference, but can't seem to do so. Does anyone know how I can get rid of it? Thanks.
    2003 Golf TDI
    Molded LCD in progress...
    Dec 2003
    Michigan
    Some volt meters require that you place a resistor across the input leads. The resistor is usually a 1 Meg Ohm or a 10 Meg Ohm value. Check the instrucions for the meter... If it doesn't say specifically that you need to, you can try placing a 1 Meg Ohm resistor across the input to the meter to see if that solves the problem. It won't hurt anything to try.
    2006 Chevy Colorado: VIA M10000 EDEN, 1 GB RAM, 80 GB 2.5" Seagate HDD, USB Slim Slot DVD/RW, Holux GPS, MobileVU 10.4" LCD (touch not working yet), VOOMPC Case (blue), 70W DC-DC supply.
    Low Bitrate ste1806's Avatar
    Nov 2003
    derbyshire u.k
    it sounds like you are making a ground loop with the earth make sure the earthing point is down to bare metal for the best connection, if this does not work try earthing to an existing earth point. hth
    Jun 2004
    Ground Loop
    If you have a ground loop go to your nearest Best Buy and get a Ground Loop Isolator. It plugs into the rca s on your amp. This should clear things up. Its like $16
    thanks for the responses, i used an existing grounding point and it cleared the interference right up. thanks!
    2003 Golf TDI
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 11:54 AM
  2. Digital Output and Mic In/Line In
    Last Post: 05-18-2006, 11:36 AM
  3. Digital audio source switching by PC - possible?
    By slushieken in forum General Hardware Discussion
    Last Post: 04-14-2004, 10:41 AM
  4. Creative Inspire 5.1 Digital 5500 on notebook
    By hkp23 in forum General Hardware Discussion
    Last Post: 04-03-2004, 08:10 PM
  5. spidf to coaxial digital
    By Mp3_Truck in forum General Hardware Discussion
    Last Post: 04-13-2001, 10:50 PM
