Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 42
Thread: Harddrive - Vertical or Horizontal
  1. #11
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    whoa, I haven't seen Grayscale post in a long long time.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  2. #12
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Quattro
  3. #13
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    hey, at least he's searching.
    edit: at the time of the original post, this was perceived to be an issue. Since then, we have learned that modern hard drives are really not all that sensitive to "normal" car vibrations. Driving around town, you are not going to kill your drive no matter what position you put your drive in. Now, if you were to go all "dukes of hazzard" with your computer running, you might have issues. But even if you didnt have a carputer, that still would be an expensive proposition.
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    I'M DEBT FREE!!
    I'm now a reasonably successful gunblogger.
  4. #14
    Constant Bitrate Eternalodyssey's Avatar
    Oct 2005
    St. Louis, MO
    Dang this post is old-skool. Rather then mulling over the pros and cons of mounting your hard drive, just to sum it all up, there is not conclusive results as to mounting your HD horizontally or vertically. The only theory that exists that mounting your HD horizontally MAY introduce vibrations which can cause the internal plates within the drive to move, getting scratches from the read/write heads in the process. I can attest to this being a possibility because I had a non-flash based MP3 player crap out on me when I used to take it running a couple years ago. That was when they first came out and I just had Creative replace it. But my vertically mounted hard drive has never suffered any skips or problems. Mount horizontally if that is what works best for you. But most seem to prefer verticle. But again, nothing concrete says either way is best.
    Check out the updates. Project 2003 Dakota worklog: http://www.mp3car.com/vbulletin/worklogs/85490-project-2003-dodge-dakota.html
    IS JACK BAUER GONNA HAVE TO SMACK A *****?
  5. #15
    Jul 2004
    Berkeley, CA
    Kevin's Last Activity: 12-31-1969 07:00 PM
  6. #16
    Mar 2006
    Colorado, but Canadian!
    Wow! He was active before he joined! By 31 years!
    1.9in x 2.9in -- 47mm x 73mm
  7. #17
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by 2k1Toaster
    Yeh! Looks like someone knowns how to time travel!
  8. #18
    Mar 2006
    And he didn't even need a flux capacitor!
  9. #19
    Jul 2004
    Berkeley, CA
    How do you know?
    Maybe he drives one of these
  10. #20
    Mar 2006
    Maybe if we all group buy () a flux capacitor, then we can travel ahead in time and get the 5 watt versions of the Pentium Extreme Editions on a 3 square centimeter board. Then we zoom back here, and add them to the store. Now we will have the ultimate PC!!!
