Results 1 to 5 of 5
Thread: Easy switch wiring question.
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    I bought a switch so my CarPuter don't turn on when I don't want it to (short trips and what not).
    It has three pegs labled: Power, Load, Ground. How the heck do I wire this thing?
    I'm using an ITPS and a PW70A. Do I take the red wire coming off the two wire plug on the ITPS and put that on the POWER lead of the switch then take the WHITE wire coming from my PW70A and put that on the LOAD lead of the switch? Then what would I do with the grounds from both the PW70A and the ITPS? Just solder them together? If that is correct then do I just find a ground wire to tap into for the GROUND lead of the switch??
    Thanks a lot!
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
    Jun 2004
    Upstate New York
    Power goes to +12v source, Load goes to the +12v lead on the device. Ground goes to ground. I assume it's a lighted switch or there'd be no reason for the ground lead. Is a 12v DC switch or a 125v AC switch. If it's an AC switch the light isn't going to work in it, however the switch will still do what it's supposed to. Install the switch on the power & ground leads coming from the vehicle.
    Constant Bitrate GWRedDragon's Avatar
    Aug 2004
    Arlington, VA
    If you're running your whole PC through the switch I hope it is a really high amp rated switch!
    Oct 2003
    Poland, OH
    The switch is a 12VDC and it is rated at 25A. Is this good enough?
    Variable Bitrate brooksware2000's Avatar
    May 2004
    Minot AFB, ND
    yep, the switch is good enough. Go for it
    Check out my hopefully useful site...
    www.hobbybotics.com
    It's still under design but it is functional
  1. Lighted rocker switch question
    By ddt in forum General Hardware Discussion
    Last Post: 05-20-2005, 07:05 PM
  2. Capture GPS data at the flip of a switch
    By Mr. Inquisitive in forum GPS
    Last Post: 02-02-2005, 06:06 PM
  3. Very cool FM transmitter and easy wiring question
    By wompser in forum General Hardware Discussion
    Last Post: 04-24-2004, 04:11 PM
  4. Need clairification on wiring on/off switch
    By syclone477 in forum Newbie
    Last Post: 03-23-2004, 04:59 PM
  5. A question (or two) about wiring
    By Thartek in forum Power Supplies
    Last Post: 08-07-2002, 07:34 PM
