Results 1 to 10 of 18
Thread: configuration Q's
    configuration Q's
    Hi,
    im new but i don't think this question fits in the newbe catagory. Well i was wondering what you guys did about storage to make it so you can just shut down your computer by just turning off the power. like preventing data loss. would it be wise of me to put the os on a compact flash ide and then all the mp3's on a harddrive so if the hd gets bumped i can just erace it and put new ones on? and what about dataloss turning it off with out selecting shutdown. also i had a quick question about the os i was thinking of using win 98lite. i was wondering how i use that. any info would be grately appriciated.
    Thanks,
    pyro
    i would be delighted if someone could help me please
    Constant Bitrate GWRedDragon's Avatar
    Aug 2004
    Arlington, VA
    Pretty much everyone uses a shutdown controller which signals the OS to shut down the PC (soft off) avoiding the problem of hard power offs. Flash cards are a bad idea because of write cycle limitations. The Opus 90w and 150w both have shutdown controllers builtin.
    Variable Bitrate heezer7's Avatar
    May 2004
    IL, USA
    I use a inverter and I have jsut beening killing the power for a while now and I have not had any problems. I know it is not the best solution but has worked for about 2 months problem free. I plan on eventually having a power/hibernate button that i can hit as i get ready to park. It is just the easiest and cheapest solution for me.
    Aug 2004
    Arlington, VA
    With an inverter you can set up a shutdown controller with a couple relays too
    May 2004
    IL, USA
    yeah, i just don't want any chance that the computer could ever be left on when i leave teh car. I have the relay that powers the inverter kill the power with the ingition. Last thing i want is to be driving home from college or where ever else and come back to a dead battery because it didn't shutdown right. Still something for the orginial poster to think about.
    ok thanks. i was also wondering what cpu u guy were using.. i have a amd 400 mhz should i underclock it to make less heat
    so whats the problem with compact flash
    Aug 2004
    Quote Originally Posted by IPyro24
    you should be fine with a 400 no prob
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Hi,
    I think I'm actually going to do just that. I'm gonna get a DiskOnModule, probably a 512mb and put my OS on that, and just have my mp3s on a hard drive. I sure hate reloading my CarPC, especially with all the special timings for my PSone Screen...
    Tidder
    Try RevFE
  1. Final configuration
    By Cris in forum General Hardware Discussion
    Last Post: 08-28-2004, 06:02 PM
  2. Change your PCM + OBD-II Qs?
    By slboytoy in forum General Hardware Discussion
    Last Post: 11-03-2003, 01:09 AM
  3. Hardware configuration OK
    By guvi in forum General Hardware Discussion
    Last Post: 10-01-2003, 08:47 AM
  4. ATI All-In-Wonder Q's
    By [email protected] in forum Off Topic
    Last Post: 09-26-2003, 05:00 AM
  5. Ok I am ready to start designing my own carpc :) Have a few Q's
    By khiser0001 in forum General Hardware Discussion
    Last Post: 05-03-2003, 12:04 AM
