You can use the onboard mic input. Just make sure the program you are using it has it's settings to use that sound source. You can also choose in windows what sound card is used for input and output. Check the sounds control panel. There should be a drop down menu. I'm not sure if you can use two simultaniously, though.
LinkBack URL
About LinkBacks
