Results 1 to 10 of 10
Thread: problems mounting dvd drive vertical ?
    Sep 2003
    Binghamton/Poughkeepsie, NY
    as the title suggests...are there any issues with mounting a DVD drive (or any CD drive for that matter) vertically. i know PS2 is built for both vertical and horizontal mounting - but i have a slot loader and was wondering if there are any issues to vertical mounting - or does it matter on the specific model drive?? thanks !!
    FLAC ppgt94's Avatar
    May 2001
    USA
    You mean on it's side? If so, it should be fine.
    Sep 2003
    no i mean vertical - a normal dvd drive is mounted horizontal - i want to take advantage of some space i have and mount the drive vertical - so in front of loading the dvd from the front -i would be loading from the top...
    Constant Bitrate Ill1's Avatar
    Jun 2004
    Woodbridge, VA
    The only problem that I could think of would be the extra force of the drive motors having to push the disk out. Realistically, as long as the drive can push the disk out, there should be no problems.
    ________________
    ______ILL.1______
    Sep 2003
    okay thanks - i will check on that - i was actually more worried of the laser being put up at a 90 degree angle when it shouldnt - but that seems to be okay i guess
    thanks!!!
    Aug 2003
    if dvd drive is slim, no problem because there are a lot of thin clients that uses slim drives and they are built to stay vertically. To be sure, check the manufacturer and ask them directly
    Maximum Bitrate EBFoxbat's Avatar
    Jun 2004
    Massachusetts
    robert42 is it a slim drive?
    ,./(0)3
    '04 Canyon 4x4 pickup
    [---PC on hold----working on external fiberglass "tool" box---]
    May 2001
    USA
    Like this (a
    or like this (b
    [kind of like you would drop a cd into the slot from above)
    Constant Bitrate snmnetwork's Avatar
    Aug 2004
    Atlanta, Ga
    I was thinking of mounting my slim slot load panasonic the same way. Any more input would be greatly appreciated.
    Status: [|||||||||-] 90% finished
    My 2000 Chevy Monte Carlo SS Install
    Aug 2003
    For panasonic try this:
    Technical Support for CD-ROM, DVD-ROM, CD-R, CD-RW and LS-120
    panasonic@bigbytecorp.com
    and say clearly that you don't have a problem with the drive, just a doubt (otherwise they will request a lot of support information). You need to know the model number.
    Good luck!!
  1. Extending USB 10' + for slim DVD drive.
    By ppgt94 in forum General Hardware Discussion
    Last Post: 08-08-2004, 01:14 AM
  2. DVD DRIVE Adaptor
    By johnnyutah36 in forum General Hardware Discussion
    Last Post: 08-04-2004, 03:15 PM
  3. USB to ide adapter + Toshiba laptop dvd drive
    By carprowler in forum General Hardware Discussion
    Last Post: 06-25-2004, 12:49 AM
  4. Hard Drive Mounting / SAVE the drive!
    By DerekR in forum General Hardware Discussion
    Last Post: 03-11-2004, 09:07 PM
  5. Confused with my new Apple Slot DVD drive, PPLS HELP!!
    By ruflyf in forum General Hardware Discussion
    Last Post: 03-05-2004, 08:03 PM
