A ground loop isolator doesn't fix the problem, but at least eliminates the symptoms. I assume you have tried grounding the inverter and power supply case?
I just bought a cd player for my truck and now my computer audio is hooked into an front aux jack, the only problem is the inverter buzzing is a lot louder than it was when I had a tape deck. How can I fix this?
ground loop isolator? If so what do those do?
@mosphere
.:@mÖ§pê®ë:.winamp.win98.pentiumII.10gig
should i ground the inverter and the computer? both?
but ground them both at the same spot
-bob
