Page 20 of 21 FirstFirst ... 101112131415161718192021 LastLast
Results 191 to 200 of 203
Thread: reversable motor for monitor?
  1. #191
    Constant Bitrate Lando's Avatar
    Apr 2002
    Mike H ,Quick question where can I get a momentary rocker switch like the one in this picture
    Aut cum scuto, aut in scuto
  2. #192
    Nov 2003
    Marietta, GA
    Lando....which picture...?
    MikeH
  3. #193
    Apr 2002
    Sorry dude, I think I should have directed this at more mods, but the one on page two of this thread. Thanx man
  4. #194
    Maximum Bitrate more mods's Avatar
    May 2003
    Atlanta, Ga.
    Quote Originally Posted by Lando
    The rocker is a power window switch.
    It's the cake having/eating thing.
  5. #195
    Apr 2002
    From where?!?!?! I can't seen to find these anywhere alone. Everyone I saw was in a 150 kit.
  6. #196
    May 2003
    Atlanta, Ga.
    Try Junk yards, you should be able to find one you like.
  7. #197
    Nov 2003
    Marietta, GA
    Randy,
    Were you ever able to connect to www.piclist.com? I think it is a Bellsouth/Atlanta area problem. I spent a half hour online with their tech group trying to get connected without success. However, the BLS guy in Florida could connect.....
    MikeH
  8. #198
    May 2003
    Atlanta, Ga.
    Quote Originally Posted by MikeH
    Randy,
    Thats a long story! I have talked many times with bellsouth. They have the same problem if they don't use the corporate machine, they say it uses different hardware to connect to the internet and that it works fine. However when they try the non-corporate machine they have the same problem that we do. From what they told me there hardware is not compatable with the hardware used by piclist.com. They have tried to contact piclist.com to work the problem out but they didn't get a reply. I believe that they have given up on resolving this problem.
    It seems to me that bellsouth could make the hardware they use more compatable instead of thrying to get others to conform to bellsouths needs, after all comcast customers have no problem with piclist.com.
    BTW they also told me that they have the same problem with other sites.
  9. #199
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    Ive seen those relays at radio shack. Also, try http://www.digikey.com
    Your choices for limiters are either microswitches or timers. Timers are gonna be about 8 bucks each. Youll probably need two, Unless your crativeand can figure out how to use one. It can be done though. I have a schamtic to reverse polarity with normal relays but its designed for a momentary switch. Not an on/off switch. If you want it, let me know.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
  10. #200
    Nov 2003
    Marietta, GA
    I wonder if there is a way to "redirect' thru someone else's network...hmmm
    MikeH
