Page 6 of 21 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 203
Thread: reversable motor for monitor?
  1. #51
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    I guess whether this works depends entirely on what you're going for. It looks like you have a switch (toggle) that switches between a manual and auto mode, with another (rocker) to jog it in/out when in manual mode. I assume the 12V line is your ign. Because you have the ign switching the middle relay, when your ignition is off, it will *always* move to the closed state.
    Is that what you want, or do you want to be able to move the montor when your car is off?
    If you want to be able to control it with the ign off, you should go back to MikeH's last schematic, modified a little bit. It also has the advantage of being somewhat simpler, using only one relay. I'll explain it in more detail if that's what you want to do.
    <edit>
    Oh, for the microswitches, you should stick them in on the 5V power lines right before the top relay, after they split. They won't cut power when in manual mode, but since that's a momentary anyway, it shouldn't matter much.
  2. #52
    Maximum Bitrate more mods's Avatar
    May 2003
    Atlanta, Ga.
    Quote Originally Posted by mushin
    <edit>
    Yes, it should work like that. I could change the toggle to a DPDT and have ign. in to auto, and bat. in to man. First I have to work out how to wire the limit switches.
    Could you give me more detail on how to wire the limit switches. I know I cant just have a switch that breaks the circuit, because then the motor couldnt run again until the switch was closed and the switch wouldnt close until the motor ran.
    Oh, btw Mike said his would not work.
    Quote Originally Posted by MikeH
    Sorry guys. It was late last night and there are some definite problems with the design I posted. The worst of which is, when you jog the screen from it's in or out limit, the limit switch closes and this forces it back it's limit point, overriding your manual jog......grrrrr.
  3. #53
    Variable Bitrate choyak's Avatar
    Jun 2004
    Buena Park, CA
    Ahh it could be something similar to a garage door opener with the limit switches. The limit switch can only prevent the direction that it is in, not the opposite direction, and it has to stop completely or it will go in a loop.
    Carputer currently 'ghettoed' into car!!!
    EPIA MII-12000
    Ampie Case with rigged extra USB
    Hitachi 60GB
    Holux GPS mouse with iGuidance 2.0
    Lilliput 7" touchscreen
    Netgear WG121 USB WiFi
    Carnetix P1260
  4. #54
    Aug 2004
    SE Michigan
    Ok, limit switches:
    relay (the top one in your diagram)
    o o
    \ \ <- switches
    5v ------------
    Basically, each switch would only break the circuit going in one direction. So you would be free to move the motor back the other way, which would then release the switch.
    The problem with Mike's was that it couldn't maintain an intermediate position. That's why I said "modified a little bit" Basically you'd put another switch in there.
    <edit>
    Gah! It cut all the white space out of my ASCII schematic! I hope it still makes some sense....
  5. #55
    May 2003
    Atlanta, Ga.
    Ok, limit switches:
    o o
    \ \ <- switches
    5v ------------
    <edit>
    Sorry, but I don't understand. Can you draw it out? I'm not that good at this so I need a lot of detail.
  6. #56
    May 2003
    Atlanta, Ga.
    ok, what do you guys think about this one. mushin showed me how/where the travel limit switches go (thanks mushin). Does this one look like it will work? Do you see any problems with it?
  7. #57
    Variable Bitrate stimps's Avatar
    Nov 2001
    brisbane
    Do a search for a guy that has done a MP3 Car project, with a Flourescent LCD display, that comes out of the top of the dashboard when he starts up, and it folds back in when he shuts the car down. He used a R/C servo motor and a small circiut (easy to biuld) to control it. No Limit switches. Its programmable too so you can adjust it to operate sweet. I was all ready to do something like this, made the printed circiut board and got the parts, and then didnt do anything more (got side tracked i guess)
    Have a look on google you never know you might find it.
    (had a look just quickly couldnt locate it.)
    Ford XR6T blueprint 4.0 L twin cam turbo.
    Xenarc 7" touchscreen M10000 Audigy 2 NX
    ITX 120W PS 80gig HD, 256MB Ram, USB wireless internet/LAN
    Griffin Powermate Panasonic DVD-CDW
    Pioneer 5x7 Four way, 2x12 pioneer subz
    600watt 6chan USA audio AMP
  8. #58
    Constant Bitrate CHUPACABRA's Avatar
    Mar 2004
    G'ville S.C.
    Why dont you just use a power side mirror setup that way you get full controle!!!!!
    P.S. whats up with that clarion mod for MC??
    2-15" ILO lcd w/DVI
    6800 gt Duel DVI out
    p4 1.6ghz flex atx board
    1gb 400 ram
    120gb(2-60gb raid) sata hd
    2-60gb hotswap
    WIN2K Pro SP2
    M.A.M.E. w/2,300 games
    CARPuter info
  9. #59
    May 2003
    Atlanta, Ga.
    Quote Originally Posted by CHUPACABRA
    Yep, I have one that I took apart. The problem with that is the pivot point, its set back to far. Go and move your mirror and watch the gap around it grow. Another problem (at least for me) is because it pivots in the center, when one side moves out the other moves back. I just wanted a close fit (no big gaps). However it would be a great solution for someone.
  10. #60
    Mar 2004
    G'ville S.C.
    close the gap with a peice of latex or some strech fabric thats what I use for my 15'' indash gap.
    2-15" ILO lcd w/DVI
    1gb 400 ram
    2-60gb hotswap
    WIN2K Pro SP2
    CARPuter info
