Results 1 to 10 of 18
Thread: Newbie Q: Battery Charge Current?
    Variable Bitrate Fox_Mulder's Avatar
    Melbourne, Australia The Truth Is Out There
    Question Newbie Q: Battery Charge Current?
    Sorry to bore you all with this newbie style question but here is my scenario:
    My stock alternator is 80 Amps, and the battery has a charge rating of 5 amps. Now if I hook up the carputer directly to the battery (with a fuse of course) will the battery be powering the car pc or will the alternator? (This is with the engine on). My concern is if the battery is powering it, and it is drawing more than 5amps then the battery will not be charging, instead it will be discharging!
    Thanks for any help!
    Fox Mulder
    2004 Toyota MR2
    Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Xenarc 700TSV TS BU353 DiNovo Mini Car2PC ODBII Bluetooth HF 16x2 Character LCD
    Maximum Bitrate VanMan69's Avatar
    May 2004
    Alameda, CA
    It will run off the alternator.
    95 Chevy G20 Vroom Boom Room
    ...with a whole bunch of nifty ****... go check it out: VanDomain Page
    Variable Bitrate cheerio's Avatar
    Jun 2004
    San Antonio
    From what you have told me, it isnt enought to determine. From my understanding of car stuff, if your car uses more than 75 amps(because your alt provides 80 amps, and your battery takes 5 of those to charge) then your battery will be getting discharged. And you have to account for everything, transmission, lights, headunit ect. If the total of all that is 75+ amps then it will be using all the power from your alt. + some power from your battery. Running your battery dead is the least of your problems, you will have enough juice in there to at least start the car(assuming it doesnt stay on constantly), but discharging your battery completely and recharging it and discharging it will limit the batterys life.
    Low Bitrate l9nux's Avatar
    Aug 2004
    San Francisco
    Get a deep cylce battery such as the Optima Yellow Top or what I've done with an Orbital Blue...
    See the bottom picture: http://www.rayheffer.com/carputer.shtml
    May 2004
    Alameda, CA
    A car doesn't take 75 amps to run, unless you've got more than one big amplifier, or if somehow you're operating all of your accessories at the same time (all power windows while adjusting all power seats with the AC and lights on and radio blaring). If you use more amps than the alternator's rating, you'll burn it out.
    The comp will run off the alternator while the car is running.
    Top Ramen lgbr's Avatar
    Feb 2004
    Spokane, WA, US
    Depending on your engine size and such. An idling car, with no accessories on, uses about 5-10 amps (depending on engine size). The carputer will run off any energy available. The carputer will use both the alternator and the battery for power. I've driven my car once with a useless battery (wouldn't charge and was dead) and the power being put out was pulsing. So basically the alternator will power it, but the battery will keep the current smooth.
    As for pulling more than 80 amps of power, your alternator will try to put out the power needed, and will melt itself. I've done this on my Honda 3 or 4 times.
    Audio Rockford Fosgate: 900 Watt 4-channel amp, 501bd Mono amp
    Computer AMD 2400+ XP, 1 GB DDR RAM, Orbit Micro 250W DC-DC PSU
    Head units are for cheaters!
    sure some girls fake orgasms.....but it's guys like me who fake the whole relationship
    Jan 2003
    Ruston, LA
    Quote Originally Posted by lgbr
    You think you would've gotten a larger one sooner..
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Feb 2004
    Spokane, WA, US
    Quote Originally Posted by frodobaggins
    Its under warranty
    Jun 2004
    San Antonio
    Im not saying a car takes 75 amps to run, but i know for a fact mine takes more than 40, because i have a 90 amp alt. and my stereo amps only have a 50 amp fuse, and my battery is draining. sot hat means my car is taking at least 40 amps
    Crouching Tiger, Drunken Kitty
    Variable Bitrate RS3RS's Avatar
    Aug 2004
    Springfield, MO
    Quote Originally Posted by cheerio
    Is this at idle or normal driving with simi-highish RPMs?
  1. Battery based tank circuit (tested)
    By Ricky327 in forum Power Supplies
    Last Post: 02-13-2008, 04:43 PM
  2. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 09:31 PM
  3. Modifying a PSU to charge a car battery?
    By crisr in forum Power Supplies
    Last Post: 07-13-2004, 06:13 PM
  4. Dual battery charger. Charge one, then the other.
    By norek in forum Power Supplies
    Last Post: 06-16-2004, 11:47 AM
  5. Will this battery over charge, 12VDC 5.1Ah NICD
    By NightHunter in forum General Hardware Discussion
    Last Post: 02-17-2004, 03:53 PM
