Hey guys, just wondering if anyone has looked into this. I mean, it has to be converted to dc power somewhere in the circuit. doesn't it?
Printable View
It would probably be cheaper (time-wise) to just buy a DC-DC.
This had bee discussed in previous posts...look thru the archives and maybe you'll find something. If I remember correctly it was determined that it would be an innefective solution.
Catlas
It can be done,but it would make the same noise like inverter,because of different grounds.I tried it,doesn't worth it.Save yourself a lot of problems and go to DC-DC, I recommend on Sproggy's one.
What do you mean it can be done? Doing so would require a complete redesign of the first stage of the supply (rectification, filtering, and the switching circuit). The only useable part of the circuit would be the final regulating stage. Even then I doubt that it would work. If it did, you would basically have a DC-DC converter (which is what a switching supply is anyway).Quote:
Aaron Cake
London, Ontario, Canada
Player: Cyrix 200, 32MB RAM, 10.2Gig Quantum HD, Onboard EtherNet/Sound/Video, Custom Lexan Case, Arise DC-DC, Win95 Kernal w/Custom Player
Car: '86 Mazda RX-7 w/Basic Performance Upgrades
I've checked out sproggy's MK2.5--it's a nice design, but it's power ratings don't come close to what i need. I'm setting up a PII 400, 256 MB RAM, NEC 4x4 CDROM Changer, Pioneer slot-load DVD, Zip Drive, 4 gig IDE, Voodoo 3 3000, SB Live Value, VHX TV/FM card, Diamond HomeFree wireless LAN, the DiscoLitez 32-light LPT circuit, and a serial port Rockwell GPS. I wish I could use that one, but I can't figure out how I'd meet my total power reqirements.
If I can't find plans for a high capacity one, I'm going to be forced to buy SunPower's 100 watt DC atx supply at $102 =(
BTW, I've scoured every reference to DC power supplies in this msg board--I found plenty of high-powered commercial PSUs, and a whole bunch of low power Maxim-based plans, but I never found any high powered kits.
The one I bought at http://www.industrialpcs.com/p_suppl...7004_12_24.htm
is a 70 watt DC-DC psu for $60 and $4 shipping. It came about 4 days after I ordered it. The best part about this psu for your setup is it comes with two connector cables, one with connections for the motherboard HD, Floppy... The other one has just HD, Floppy connectors.
So it looks real easy to use more than one to get all the power you need.
You don't need to redesine the circuit.What I did was making a 50hz sine wave generator (it's 220v here) producing 220v through transformer,and putting it to the input of AT PSU.This is very similar to inverter. There were a few problems:you have to use quite a big transformer because of large currents,and it makes some buzzing noise,probably because the generator didn't produce pure sine wave.Quote:
Originally posted by Aaron Cake:
What do you mean it can be done? Doing so would require a complete redesign of the first stage of the supply (rectification, filtering, and the switching circuit.
HappyPuppy:yes,it seems like you need a very powerful PSU.If you have some idea in electronics you can redesign the Sproggy's DC-DC to make it more powerful.The most current "hungry" voltages are 5v and 12v.If you know using Protel,you can add more 5v and 12v sections to the circuit.
So all you did was build an inverter? This has exactly the same problem as running a commercial inverter. Namely, innefficiency and noise.Quote:
For all that trouble, a $79 DC-DC converter sounds better and better...
Aaron Cake
Well, the Industrial PCs idea would be good for an at PSU, but the only two DC ATX PSUs they sell are for 24 and 48 volt systems, and I don't feel like trying to wire THAT up.
If some one could let me "examine" a copy of this Protel, I might try my hand at designing a real bad boy PSU, something that can really handle some major wattage. After all, who here JUST wants a MP3 Player?
