Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Multiple Displays
  1. #11
    Sep 2000
    LA, CA, USA
    Post
    Ok so I figured I could just use the multiple input feature of my front monitor and then use the remote to switch the sources when i wanted the same thing on all monitors. Probably more effective than a software solution or maybe depends on video card.
    Also...here's an electronics question for all ya ee wizards out there more advanced than me:
    How can I setup a circuit that will feed my monitor a static image immediately after powered and allow ntsc input to pass through either after a certain amount of time or when a signal is received from ... say the parallel port of the computer that has finished loading windows?
    This would be sweeeet so I don't have to look at boot screens ever again .
  2. #12
    Sep 2000
    LA, CA, USA
    Post
    Ok I ordered another monitor for home today cause it was such a good deal. I now need two video cards at home as well as in the car. So I thought I'd just add one more quesiton while we're on the topic. I don't do any gaming, so I need a video card for the second monitor that will be good enough for video and photo. What specs would fit my needs and still be inexpensive? Also, I don't have anymore free PCI slots at home. Can I use an ISA video card? I know it's limited to 16-bit, right? But is this enough for my purposes?
    Thanks in advance.
  3. #13
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    Post
    I have run an extended desktop (ie, multiple monitors) on the last 3 motherboards I have owned. all 3 had onboard video which worked fine as the secondary monitor, all 3 used the same ATI AIW as the primary monitor, and all 3 were run with WIN98.
    The problems you are going to have will consist of the following:
    1. you can only have 1 primary display card. DVD software generally only allows you to veiw DVD's on the primary display
    2. your primary display is where windows is going to default its icons (meaning that the START bar and all icons will be placed on the primary display every time you boot up) This can be bad if you have set the rear display to be primary, because you wont be able to see any of the controls from the driver's seat.
    On a happy note, its easy to make all of your (NTSC) displays see the same thing--just use an RCA splitter. If you are using multiple VGA screens, then you obviously have enough money to pay someone to figure it out for you, because damn those things are expensive
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    I'M DEBT FREE!!
    I'm now a reasonably successful gunblogger.
  4. #14
    Sep 2000
    LA, CA, USA
    Post
    Oh really? Even when you move the icons and everything to the other display the start menu moves back over to the primary? I thought windows remembered the positions and reloaded them on startup. Hmmm. It probably won't be a problem as long as it doesn't do that for program windows.
    And yes they are NTSC.
  5. #15
    Jun 2000
    Nashville
    Post
    sometimes it remembered, sometimes it didnt. I got so fed up with it I just said screw it and quit trying. Maybe it was my computer or the ATI software or something
    I'M DEBT FREE!!
