Results 1 to 10 of 12
Thread: Where to buy plexi glass from?
    Mar 2004
    Marietta, GA
    Hi all... I am looking for somewhere to buy plexi glass? I have been seeing all the great cases made from plexi and would like to give it a shot.
    Are they available at "national chains" like Home Depot, West Marine... etc???
    What do you use to cut plexi ? ...Dremel ?
    Thanks folks!
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    home depot sells it but you want like 1/4 inch plexi so its not too flimsy.. thats just my 2 cents.. I'm not sure home depot carries it.
    I found mine in a local plastics manufactor. The best way to cut it is like glass.. you etch it then just apply some preasure and it should break along the line.
    '98 Explorer Sport
    80% done
    Low Bitrate microbionic's Avatar
    Aug 2004
    medina,ohio
    Central NY
    Doesn't plexiglass have problems with static electricity, or how do you guys deal with this? Are there any sites that have some good tips on putting plexiglass cases together? Thanks!
    Maximum Bitrate owenjh's Avatar
    Nov 2003
    NC
    I used the thickest plastic they carried at home depot. For static, I used the standoff's that come with cases... I still have to link them together for grounding purposes. I have pics of my case, just need to compose something on how I made it... if you request, I may just do that.
    CarComputer Status: New Car & Broken (Motherboard Fried)
    Owen JH | My Linux Blog | The Tech Fellows
    Central NY
    I would definitely be interested in that and will have to check out Home Depot. Thanks!
    Mar 2004
    Marietta, GA
    Quote Originally Posted by electron
    Thanks for the tips on where to look and sizes to get. Geez... I didn't really think about static! I too would like some instructions when you have a sec!
    Thanks.
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    Static is a concern on cases, like plexi, that don't dissipate it well. That said, I don't think it's a large risk - I've done such a case, as have many others, without problems. Though if you expect it to be rubbing against carpet and such, matters may be a little different . If you want to be prudent/paranoid, sticking grounding points around the case can help dissipate static.
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    McMaster-Carr has everything, including static-dissipative plastic. Look under Raw Materials.
    You won't find this stuff at Home Depot.
    Maximum Bitrate jzgt's Avatar
    Mar 2002
    Couldn't you just attach a wire from the plexi to some sheet metal on the car to discharge it?
    - Jeff
  1. What to use to "glue" plexi glass or acrylic?
    By riddle14 in forum Fabrication
    Last Post: 04-19-2004, 01:01 PM
  2. Vote for a Money Order Lilliput Group Buy
    By NightHunter in forum LCD/Display
    Last Post: 03-19-2004, 06:34 PM
  3. Making new case lid out of plexi....
    By THEMP3KID in forum General Hardware Discussion
    Last Post: 04-22-2002, 12:25 PM
  4. Would you buy a plexiglass case, prefabed for a fv24?
    By surfer6262 in forum Classified Archive
    Last Post: 04-17-2002, 11:46 PM
