Is there an adaptor that will allow me to fit a din HU and another din device in a standard double din space? do i even need an adaptor? I have a nissan xterra 2003. and yes i did do some searching =)
The stereo opening is double-DIN.Quote:
Originally Posted by ucidave
That means two 1-DIN units can fit in there. It's likely you won't need a mounting kit. I checked C-field for your ride and the only mounting kit is for a single 1-DIN unit with a storage pocket taking up the second DIN slot.
All depends how your particular car mounts stereos.
In my old mitsubishi that had double-din, there were a pair of plates (one either side) that you screwed to your headunit (or pair of headunits), then slotted this in place.
Yours may be similar. Have you actually tried to remove your current unit???
All of my Toyotas had metal brackets on the side of the factory stereo that held the stereo inplace and allowed 2 single din units to be mounted. When I put in my first aftermarket cd deck-I bought a pocket to fill in the bottom din opening.
