Results 1 to 4 of 4
Thread: double din adaptor? 2 1-din devices in a double din space possible?
    Dec 2003
    Is there an adaptor that will allow me to fit a din HU and another din device in a standard double din space? do i even need an adaptor? I have a nissan xterra 2003. and yes i did do some searching =)
    Elsewhere
    Quote Originally Posted by ucidave
    The stereo opening is double-DIN.
    That means two 1-DIN units can fit in there. It's likely you won't need a mounting kit. I checked C-field for your ride and the only mounting kit is for a single 1-DIN unit with a storage pocket taking up the second DIN slot.
    How about the Wiki?
    Maximum Bitrate GingerPrince's Avatar
    Apr 2003
    Leeds, UK
    All depends how your particular car mounts stereos.
    In my old mitsubishi that had double-din, there were a pair of plates (one either side) that you screwed to your headunit (or pair of headunits), then slotted this in place.
    Yours may be similar. Have you actually tried to remove your current unit???
    GingerPrince
    Car changed for TVR Griffith 500, so computer de-installed. Using a Dension 100ix w/60Gb HD unit in the interim.
    Carputer Install - http://www.stuffandting.com/carputer/
    CarBox Software -- http://www.stuffandting.com/carbox/
    Variable Bitrate rgardjr's Avatar
    Oct 2003
    All of my Toyotas had metal brackets on the side of the factory stereo that held the stereo inplace and allowed 2 single din units to be mounted. When I put in my first aftermarket cd deck-I bought a pocket to fill in the bottom din opening.
  1. Double DIN
    By mutilator in forum General MP3Car Discussion
    Last Post: 08-23-2009, 06:36 PM
  2. DIN and Double DIN Dimensions/Standards
    By kubark42 in forum General Hardware Discussion
    Last Post: 08-05-2009, 02:39 PM
  3. Double Din Kit for LCD Mount?
    By Plinkey in forum LCD/Display
    Last Post: 07-13-2004, 11:41 PM
  4. Can double din hold pull out and radio?
    By jnusaira in forum Fabrication
    Last Post: 06-08-2004, 04:32 PM
  5. Replies: 6
    Last Post: 10-21-2003, 04:33 AM
