Results 1 to 4 of 4
Thread: building an internal enclosure
    Jun 2004
    Ontario, Canada
    i want to build a slot that which i can slide a enclosure for a 160gb 3.5" hd, i have the casing for a 5.25" from an old cdrom i gutted, i want to be able to slide the enclosure in and it will align with the power and usb, the extra space in the case will be filled with foam to keep the enclosure snug, good idea?? has anyone done this? pics?
    also can i use the computers power supply and adapt one of the plugs to the little power plug it uses, sorry i don't know much about how electricity works, i'm working on learning more but can anyone help?
    one of the microatx cases i plan to get has 2 hidden 5.25" slots, and if i can get this to work it would be awesome, if its possible
    thanks
    Constant Bitrate mindscream's Avatar
    Jun 2004
    Memphis
    You might want to consider modifying a removable hard drive bay.
    Based on your description, I think that would be along the lines of what you're wanting. These can be found almost everywhere. I'd start with Ebay or if you're that anxious, A local comp store.
    Mind Scream out
    Jun 2004
    Ontario, Canada
    oh damn thanks, i couldnt find these, i was always searching "internal enclosure" and along those lines so i came up with nothing
    Jun 2004
    Memphis
    Glad to help
    Mind Scream out
  1. internal enclosure?
    By sevsev in forum General Hardware Discussion
    Last Post: 09-18-2004, 03:48 PM
  2. slim optical enclosure with internal battery
    By zPilott in forum General Hardware Discussion
    Last Post: 08-23-2004, 07:29 PM
  3. Building enclosure and mounting questions
    By oekundar in forum General Hardware Discussion
    Last Post: 08-23-2004, 03:09 PM
  4. Building an enclosure for the LCD?
    By Optikal in forum Fabrication
    Last Post: 07-12-2004, 12:11 PM
  5. dvd external enclosure drive
    By kuo in forum General Hardware Discussion
    Last Post: 03-07-2004, 05:36 PM
