Results 1 to 9 of 9
Thread: Need Desktop HD to laptop Mobo Connector
    Newbie Joe_Collectible's Avatar
    Nashville TN
    Where can I find a connector that will allow me to use a desktop HD to connect to the laptop Mobo? I don't mean to use an external, I need something to boot the OS with. (yes i read that 2.5's use less power and space, but I only have $50 in my carputer so far, keeping it budget-simple. Besides I am upgrading my vehicle's charging system to maintain a higer more constant voltage level. And I want a 7200 rpm HD.
    mini 44 pin (laptop Mobo) IDE to standard 44 pin (desktop HD) IDE
    Or else I have to do this:
    http://hypertext.rmit.edu.au/~blogs/...es/000315.html
    will the laptops mobo supply a desktop HD with enough voltage? It's IDE right? just diff connectors?
    Also, how do I determine how many ampere's my power supply will draw?
    my vehicle stock alternator is 105 amp
    vehicle and current draw 60 for vehicle and 20-30 for sound setup. (roughly)
    Variable Bitrate Pabs's Avatar
    May 2004
    Somewhere in the UK
    always a good place to check ebay....
    loads of this type of stuff on there usually.
    Nashville TN
    I need a desktop HD to laptop mobo... not a laptop HD to desktop mobo
    (see link)
    Jul 2003
    San Diego,CA
    Quote Originally Posted by Joe_Collectible
    (see link)
    I would just get external usb case for the drive (~$10-$20) and go in through usb
    oh you don't want an external ... it may be the case that your laptop will not recognize larger drives than it came with unless there are bios flashes for the mobo.
    There are 7200rpm laptop drives .. I just got 5400rpm 16MB cache drive for my toshiba and I did see 7200rpm ones
    Shuttle xPC w/ Athlon 2400+
    512MB ddr266
    GeForce4 128MB agp video
    250GB WD SE
    USB2.0 DVD/CD-RW slim drive
    7" Xenarc TSV touchscreen
    PAC Audio AUX input module
    Opus 150W PS
    iGuidance usb GPS
    RF keyboard/mouse
    Mobile Media Center
    Constant Bitrate CHUPACABRA's Avatar
    Mar 2004
    G'ville S.C.
    I think you guys like to make life harder for yourself than you should for the time and effort go buy a external hdd case and runn it off that.
    2-15" ILO lcd w/DVI
    6800 gt Duel DVI out
    p4 1.6ghz flex atx board
    1gb 400 ram
    120gb(2-60gb raid) sata hd
    2-60gb hotswap
    WIN2K Pro SP2
    M.A.M.E. w/2,300 games
    CARPuter info
    Maximum Bitrate EBFoxbat's Avatar
    Jun 2004
    Massachusetts
    3.5" HDD needs 12v... Laptop only gives 5... its external 3.5 or buy a lappy hdd
    ,./(0)3
    '04 Canyon 4x4 pickup
    [---PC on hold----working on external fiberglass "tool" box---]
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by EBFoxbat
    Yup, your lappy won't put out enough.
    Tidder
    Try RevFE
    Nashville TN
    I thought that the laptop was actually 18v and that I will need to run a series of in-line resistors in order to bring the current down to 12v. So you all are saying it is 5v; that is no problem. If it's only 5v, I can run a seperate power supply in order to power the desktop HD. I have access to a few desktop HD's. I don't want to spend money on a laptop HD. Does anyone know where a connector might be, otherwise I will have to make one.
    Or, as you all say, simplest would be adding an external via usb... I need a HD to boot my OS from. Your saying that I can boot my OS from an external USB drive? It will only be usb 1.1 then, right? Cuz that is what my laptop is. I can't use a pci -mca card for USB 2.0, because it will only recognize the card after the OS boots up... or do I even have that option with a laptop. I mean, do they even make 2.0 cards for laptops? I am not familiar with laptops at all.
    Sep 2003
    New Mexico, USA
    If your laptop is too old, it won't boot from USB either. Yes, they do make PCMCIA USB 2.0 cards. They run somewhere around $50 for something decent.
    Tidder
    Try RevFE
  1. epia m1000 nehmiah + laptop HD problems
    By chicochu in forum General Hardware Discussion
    Last Post: 07-14-2004, 05:15 PM
  2. Need help with External USB Laptop HD
    By VWTronics in forum General Hardware Discussion
    Last Post: 05-26-2004, 01:58 PM
  3. Newbie asks ? Laptop based carputer vs desktop pc based carputer
    By SAScooby in forum General Hardware Discussion
    Last Post: 03-01-2004, 02:59 PM
  4. Replies: 10
    Last Post: 01-30-2004, 08:47 PM
  5. Replies: 11
    Last Post: 11-29-2003, 01:36 AM
