Results 1 to 2 of 2
Thread: kinda at a standstill
    I have the computer/touchscreen installed, and are installing a temp set of speakers.
    my question is...what would be a GOOD set up for speakers amp...not going overboard. This is in a Corvette so the space limitations are small...
    is extra noise/static a problem, or is the sound coming out of most computers prety good? is there a advantage to using USB sound card out as opposed to the normal speakers out?
    thanks
    No idea on a GOOD setup but on your other question...
    Sound is usually good, EXCEPT for ground problems I have found. A USB sound card has helped some people, but for me it made no difference as all my noise (high pitched whine) was coming on the ground signal. I had to use a ground loop isolator to get the whine to go away. This probably affects the sound quality a bit, but it sounds good to me. Almost no noise and certainly nothing for a car enviroment. You can get that filter from Radio Shack or any number of other places. Good luck.
  1. Replies: 5
    Last Post: 09-28-2003, 05:57 AM
  2. Kinda new to this mp3 car thing, Have a few ???'s Thanks.
    By Red95GST in forum General Hardware Discussion
    Last Post: 07-29-2002, 11:23 AM
  3. Using an old VGA TFT monitor... (kinda long)
    By MikeHunt79 in forum LCD/Display
    Last Post: 11-12-2001, 09:36 AM
  4. touchscreen (first post, kinda long)
    By poolguy in forum LCD/Display
    Last Post: 11-08-2001, 11:38 AM
  5. what kinda wattage do i need?
    By GrendelT in forum General Hardware Discussion
    Last Post: 08-30-2000, 03:05 PM
