Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: AMD 2200+ running hot
  1. #11
    Newbie Joe_Collectible's Avatar
    Nashville TN
    Quote Originally Posted by god_of_cpu
    So are P4's, in fact even more so:
    Pentium 4 3.06 GHz = 81.8 watts
    Athlon XP 2200+ 1.65 V = 67.9 watts
    exactly. Hence the m3 technology and 2x less power consumption/heat
  2. #12
    It's possible it does simly run that hot, mine in a case runs about 52 degrees celsius. It should be fine, and use the hundreds you saved over the P4 to buy a nice LCD.....
  3. #13
    May 2004
    whats the max temp a athlon xp proccessor should reach (I have a 1400+) before it kills itself?
  4. #14
    Rochester, NY
    Which is kinda my point since my desktop is a P4 3.0GHz OCed to 3.3GHz and is running 25 degrees C cooler than the AMD
    89 Mustang (Autox, road race, and cruiser)
    93 Escort (Daily Driver)
    84 Dolphin RV (Soon to be Carputer Heaven)
  5. #15
    New York
    Depends on the AmD Processor you got. But 80 deg c is the max number I believe. But at 65deg c on other dies. just go check out the spec sheet for your specific processor. 65 deg seems hot though. i'm running a 2000+ and averaged maxed 63 with an average of 50 in the middle of the summer. but must admit, was using cpuidle to help cool the proccessor which did lower my temps a good 10deg c.
  6. #16
    May 2004
    crap, my processor is running at 75c is there anthing I can do to fix this, I have a coolmaster heatsink and fan, two 12mm exaust fans, and one 12mm fan blowing cold air in. What should I do about this/?
  7. #17
    Deactivated Diewlay Lowmo's Avatar
    Aug 2004
    wow ... 75 celcius
  8. #18
    Rochester, NY
    75C is waay too hot for sure. I'm suprised it's stable. Try replacing the thermal compound with a quality one such as Arctic Silver.
  9. #19
    New York
    Yea, definitely try to reseat the heatsink on the processor with new compound. 75 is very high, no matter what, you got some serious cooling issues. Not feeling the 12mm Fans either. Sounds like too little airflow. I would consider upgrading to a 3.5" fan that would be able to output atleast 50cfm if not more.
  10. #20
    Variable Bitrate lawrence's Avatar
    Oct 2003
    carol stream illinois
    try to slow down the fan if you move air too fast across a heat sink it will not disapate / absorb the heat. also try a larger heat sink with a smaller cfm fan
    or a fresh air intake duct from out side of case to feed just the cpu.
  1. power problems while car is running..
    By TimW in forum General Hardware Discussion
    Last Post: 03-18-2006, 09:11 PM
  2. Replies: 2
    Last Post: 12-17-2004, 01:27 PM
  3. Hot Hot OPUS!!
    By god_of_cpu in forum Power Supplies
    Last Post: 06-22-2004, 05:02 PM
  4. Running Two Computers?
    By dapilot in forum Power Supplies
    Last Post: 04-15-2004, 08:14 AM
  5. LCD running very hot
    By Stoney in forum LCD/Display
    Last Post: 02-27-2002, 02:07 PM
