Results 1 to 4 of 4
Thread: Grounding question.
    Jun 2004
    North West England
    Question Grounding question.
    Hello,
    got a quick grounding question, a brief outline of what’s happening, with no ground on DVD or inverter I get lines on LCD screen and buzzing out of speakers. That’s fair enough, I use a cheap inverter. When I ground the DVD player the buzzing sound stops, cool. When I ground the inverter the lines stop, sorted! However, this is the odd bit, when I ground both items the lines on the screen come back!! Both grounds go to the same point in the boot. Any ideas what’s happening here. Searched but didn’t see this particular problem.
    Thanks in advance
    Barney
    B A R N E Y 0 0 0 1 - 99 Subaru Impreza
    Pioneer DEH-P9400MP - Kenwood KAC-PS521 amp - Infinity speakers - Rockford Fosgate subs - 7" Lilliput - DVD or XBOX - 60 % finished - need to sort boot :-)
    Maximum Bitrate bertybassett's Avatar
    Sep 2003
    Gloucester (UK)
    try diferent grounding locations.
    Jul 2004
    Quote Originally Posted by bertybassett
    Yep. What he said. This should clear it up. Be sure to grind away any paint where you attach your grounds.
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    I thought you had to ground everything in one place, otherwise you would be creating a ground loop. Is this correct or is it ok to ground in multiple places.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  1. Grounding question
    By Telos in forum Car Audio
    Last Post: 07-24-2004, 04:13 PM
  2. DVD drive question
    By Pokey in forum Newbie
    Last Post: 05-11-2004, 05:26 PM
  3. Grounding concern (not normal grounding issue)
    By supralightning in forum Power Supplies
    Last Post: 03-22-2004, 01:02 AM
  4. newb grounding question...
    By bstanton in forum General Hardware Discussion
    Last Post: 01-15-2003, 02:02 PM
  5. FV24 grounding question
    By Squeezer in forum General Hardware Discussion
    Last Post: 03-21-2002, 05:06 PM
