Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Fuse blows with crank
  1. #11
    Low Bitrate swingpoha's Avatar
    Jul 2004
    I agree that the PSU is not blowing the fuse, obviously I am shorting or it is grounding out like some above have said. The question remains what is different when I crank the starter vs. just switching to the acc setting with the key. If the system has a short, it should always blow a fuse and as far as I know there is no contact between the computer system and the ignition wire to the starter. I was asking if anyone knew what is changing to cause the short when I crank the starter.
    My obligatory progress meter.
    [|||||||||||||||||||-] = 95%
    Basic Install done and all bugs fixed.
    Need: GPS, OBD
  2. #12
    Jul 2004
    My setup is simply a wire directly from the battery running directly to the carnetix(with fuseholder in-line), I have looked at every inch of the wire between those two points, there is no obvious place where it could be shorting out, perhaps it is shorting somewhere in my computer but again, why would it only happen specifically when I crank the engine.
    Need: GPS, OBD
  3. #13
    FLAC ppgt94's Avatar
    May 2001
    USA
    Quote Originally Posted by swingpoha
    No ground wire? How about remote/acc?
  4. #14
    Mar 2004
    Vancouver, BC, Canada
    Quote Originally Posted by ppgt94
    Yeah, please tell us where you ground wire and acc wires are connected to and from.
    I don't know much about the carnetix PSU, but if it has a remote/acc wire, then try disconnecting that, and just hook it up to the +9v on a 9v battery, and hook the 9v battery ground to the PSU ground. That way you should be able to tell if it is the acc wire from your ignition or head unit that is causing the short.
  1. relay, inverter, fuse problems
    By cheesyhoward in forum Power Supplies
    Last Post: 06-02-2005, 09:04 AM
  2. Wiring Distribution Fuse Box, cable length etc
    By Pabs in forum General Hardware Discussion
    Last Post: 09-06-2004, 04:59 PM
  3. relay, inverter, fuse problems
    By cheesyhoward in forum General Hardware Discussion
    Last Post: 06-22-2004, 03:05 PM
  4. quick fuse question....
    By jusatry in forum General Hardware Discussion
    Last Post: 02-23-2004, 10:54 PM
  5. Which fuse type/holder do i really need?
    By Euclid in forum General Hardware Discussion
    Last Post: 11-04-2002, 03:00 AM
