Results 1 to 10 of 14
Thread: Fuse blows with crank
    Low Bitrate swingpoha's Avatar
    Jul 2004
    I have a carnetix power supply and I have it connected to the battery directly with a 10A fuse inline. The shutdown controller and power supply work great if I just move my key from off to acc and back , however, as soon as I crank the engine the fuse blows every time yet it never blows unless I crank the engine. The fuse blows before you hear the cranking sound though. Any ideas? Hopefully this is my last problem, thanks.
    Jason
    My obligatory progress meter.
    [|||||||||||||||||||-] = 95%
    Basic Install done and all bugs fixed.
    Need: GPS, OBD
    Mar 2004
    Vancouver, BC, Canada
    There is something shorting between your ignition system and your computer power.
    I would check all of the power cables going from your battery to your computer.
    Jul 2004
    I just tried a 15A and 20A fuse and it completely fried them both. I but a 10 amp fuse back in and measured the voltage at the battery with a volatage meter and during crank the voltage does not drop below 10 volts. I don't think it is because the system is pulling to may amps. What is different when you crank that would cause the fuse to blow?
    To Achi: Why would it only blow when you crank if there was a short. Like I said as long as you don't crank it works great.
    Need: GPS, OBD
    Maximum Bitrate Change's Avatar
    Aug 2004
    California
    My guess would be that the voltage dips down as the starter motor draws a huge chunk o' current for spinup, the computer power supply tries to compensate for the dropped voltage by drawing more current, and this blows the fuse.
    Once the switch hits Start, even if the starter motor isn't spinning yet, it's still drawing current to get it spinning.
    If your battery is too old, it may need to be replaced to keep the voltage up during cranking. Hmm. Or you're using too small a gauge wire to the Carnetix supply...smaller gauge wire increases the amount of voltage drop per unit length. With the vehicle off, check the voltage at the battery, and then again at the Carnetix. There shouldn't be a lot of difference. If there is, you need a bigger power cable. Also, leave a voltmeter wired to the battery and crank it, see how low it dips.
    You can also ask on the Carnetix forums at http://www.carnetix.com/forum
    Jul 2004
    Like I said I measured the voltage at the battery during crank and it did not drop below 10 amps. I am using 10 gauge wire from the battery. I also tried a 20 A fuse and it blew so that would mean the voltage would have to drop to 3volts to fry a 20 amp fuse since my system has a 60W power supply. I am totally confused, any ideas? Thanks Jason
    Need: GPS, OBD
    Mar 2004
    Voltage is pushed through a circuit, Amperage is pulled through a circuit.
    The only way you are going to blow a 10amp fuse is if something on the circuit the fuse is protecting is pulling more than 10 amps.
    If you have a short in the system, where there is no resistance between positive and negative, then your car battery or starter motor will pull the maximum amperage they can.
    Your PSU is not what is blowing your fuse.
    Unless I'm on crack.
    Maximum Bitrate falconey's Avatar
    Feb 2004
    Atlanta
    Something's not wired correctly. Post pics if you can or explain your set up as far as how you have the wires running(power that is). Also do you have amps?
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    dont keep upgrading your fuses. thats the last thing youy want to do.
    Newbie Joe_Collectible's Avatar
    Nashville TN
    wire is grounding out
    Quote Originally Posted by swingpoha
    If your blowing fuses, why did you measure the voltage durring cranking? You should have measured current. Try this, throw a N4001 or a N4004 before the fuse.
  1. relay, inverter, fuse problems
    By cheesyhoward in forum Power Supplies
    Last Post: 06-02-2005, 10:04 AM
  2. Wiring Distribution Fuse Box, cable length etc
    By Pabs in forum General Hardware Discussion
    Last Post: 09-06-2004, 05:59 PM
  3. relay, inverter, fuse problems
    By cheesyhoward in forum General Hardware Discussion
    Last Post: 06-22-2004, 04:05 PM
  4. quick fuse question....
    By jusatry in forum General Hardware Discussion
    Last Post: 02-23-2004, 11:54 PM
  5. Which fuse type/holder do i really need?
    By Euclid in forum General Hardware Discussion
    Last Post: 11-04-2002, 04:00 AM
