Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 47
Thread: DVD Drive Horror!
  1. #21
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    Quote Originally Posted by c0rrupti0n
    I did read your previous post and was meaning to comment on it. I thought that the higher the guage the less current used, the more power the device has...(when dealing with a small amount of power such as 5 volts). However the more voltage requires a lower guage to avoid heading up the wire.
    Thanks for your help I plan to give it a shot tomorrow...
    First, I hope you didn't take my last post as being harsh... I didn't mean it that way
    Anyway, higher the gauge, the smaller the wire. The smaller the wire, the greater resistance. The greater resistance, the greater voltage drop, and the more power dissapated (as heat.) This is true regardless of voltage. You're right that a lower gauge wire heats up less, but not that a higher gauge consumes less current (in fact, the lost power is what becomes heat.)
    I think you've pretty much nailed the cause of your problem, and you're on the cusp of making it work. You just got the electrical properties of wire a little mixed up
  2. #22
    Constant Bitrate c0rrupti0n's Avatar
    Mar 2004
    Miami
    Your the man mushin, Thanks so much for the explaination. Im going to try a 12 guage. I will let yeah know what happens tomorrow...
    Out of curiousity, lets say you use a 0 guage wire at 15 feet with 5 volts. Would that work? Just seems like theres so much metal and yet so lil voltage to push across such a large wire.
  3. #23
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    I think it would more depend on the quality of wire than length. Less resisitance, longer shot, more resistance, shorter shot. If you use really good really low resistance wire, I'm sure you could shoot longer than 15 feet.
    Edit: Radioshack in my opinion does not carry quality wire.
    Tidder
    Try RevFE
  4. #24
    Variable Bitrate choyak's Avatar
    Jun 2004
    Buena Park, CA
    There are not really very many alternatives available for 'quality of wire'. Most wire is copper. The only better wire would be either gold or silver, and the expense would be excessive. The other alternative is to obtain a 'switching regulator' that would connect to the ignition and supply the 5 volts. This would remove the 5 volts when the key is switched off, causing unknown disturbances to the carputer (probably appears as removal of a USB device). An example of a switching regulator would be a modified Lilliput egg.
    http://www.carnetix.com/lilli_usb_mo..._usb_mod_1.htm
    Carputer currently 'ghettoed' into car!!!
    EPIA MII-12000
    Ampie Case with rigged extra USB
    Hitachi 60GB
    Holux GPS mouse with iGuidance 2.0
    Lilliput 7" touchscreen
    Netgear WG121 USB WiFi
    Carnetix P1260
  5. #25
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    The best wire you can get without going exotic is from your local hobby store. Should have 12-16 guage in spools, but it isnt cheap. There are a hundred times as many strands of silver wire inside a silicone case. If you can afford it I would recommed going that way. Do it once the right way versus how many times trying to save money.
    2005 Ford Focus ST
  6. #26
    Aug 2004
    SE Michigan
    Yes, 0 gauge wire would work for you, aside from being ridiculous overkill. More metal doesn't make it harder for current to flow, it makes it easier. As a rough analogy, think of it as road size. Bigger wire is like having more lanes; given the same amount of traffic, it'll be able to flow more smoothly without as much road rage (heat).
  7. #27
    Variable Bitrate stimps's Avatar
    Nov 2001
    brisbane
    If your still having problems, It may be a impedance issue. Try putting a power supply at the cd rom. Search for the sproggy power supply information, and biuld yourself a small single circiut 12 to 5 volt switch mode power supply. Then the cd will see a perfect 5 volts, with no fluctuations no matter what the drive is doing. Even if your 15 foot power cable is dropping from 12 volts to 10 volts, doesnt matter the power supply will take care of it.
    Just my suggestion, a way to solve the worse case senario i guess.
    Hey it worked for me!
    (audigy nx 2 in rear of vehicle, PC in front. Put a 5 volt sproggy style supply right next to the audigy nx, small cable from that to the front to the rest of the PC. SOLVED my noise problems totally.)
    Ford XR6T blueprint 4.0 L twin cam turbo.
    Xenarc 7" touchscreen M10000 Audigy 2 NX
    ITX 120W PS 80gig HD, 256MB Ram, USB wireless internet/LAN
    Griffin Powermate Panasonic DVD-CDW
    Pioneer 5x7 Four way, 2x12 pioneer subz
    600watt 6chan USA audio AMP
  8. #28
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    the thicker the wire the easier it is for the current to travel, think of a resistor, if you put another one in parallel the resistance decreases, add another one and it decreases again but a somewhat less amount, the more resistors you add the closer the resistance gets to 0, this is effectivley what your are doing by making the wire thicker.
    edit: didnt realise this was already explained by mushin
    Signature: [==||========] 20% complete
  9. #29
    Constant Bitrate Ill1's Avatar
    Jun 2004
    Woodbridge, VA
    I would like to comment about the type of wire used. Just like everyone is saying, larger wire => more power to device. But I would argue about using different types of wire. If my memory serves me, copper is a better conductor than gold or silver. The reason gold is used in audio equipment, is that no naturally occuring substance corrodes gold. The tighter the wire is wrapped and the thicker the wire is, are the only factors that pertain to wire quality in your situation. Hope this helps.
    ________________
    ______ILL.1______
  10. #30
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by mushin
    Also could think of your car as a really huge wire (i know not really, but go with it). You can get a good ground just about anywhere that's metal.
    Tidder
    Try RevFE
  1. Best remote DVD drive option
    By lookinco in forum General Hardware Discussion
    Last Post: 08-09-2004, 12:28 PM
  2. Slim Dvd Drive or Fat drive?
    By yunusyu in forum Input Devices
    Last Post: 05-28-2004, 08:06 PM
  3. DVD drive problems... Anyone have any ideas?
    By coachreed in forum General Hardware Discussion
    Last Post: 05-27-2004, 10:35 PM
  4. Slimline IBM DVD drive up for sale
    By mpattonm in forum General Hardware Discussion
    Last Post: 04-15-2004, 04:30 PM
  5. DVD Drive Question (slot loading)
    By breimann in forum Newbie
    Last Post: 03-09-2004, 06:20 AM
