Page 1 of 5 12345 LastLast
Results 1 to 10 of 47
Thread: DVD Drive Horror!
    Constant Bitrate c0rrupti0n's Avatar
    Mar 2004
    Miami
    Angry DVD Drive Horror!
    Ok Have 4 drives and many many moons later. I almost have my CD-Drive working! However I recently ran into a new hurtle. I will describe my setup real quick.
    Im running an Opus 150watt, that powers pretty much everything
    I have 15 foot power/usb/monitor cables all running from the rear to the front console. Im using a slot loadable DVD/CDRW laptop drive converted to IDE then to USB.
    My issue is that my cd-rom drive need 5 volts and can only be powered from the opus with a length no more than 5 feet. However I need atleast 12 feet for it to reach the front console.
    It seem current or amperage or what have you(im no electrician) drops enough after 5 feet for the drive to seize operation.
    Tomorrow after Hurricane Jeanne, I plan to pickup a DC 12 to 5 volt converter from Radio Shack. Then tap into the 12volt line of the Opus rather than the 5 then connect the converter to drop the voltage to 5. Im hoping this will work. Not sure what else I could try aside from taping into the cars ignition (which i want to avoid outside power sources).
    Could anyone give me a hint as to why this is happening? Or maybe a better alternative? I'd really appreciate any input... Thanks (soon pics will be posted)
    Constant Bitrate mikevsgeek's Avatar
    Jul 2004
    Auburn Maine
    Quote Originally Posted by c0rrupti0n
    try using a lower gauge wire maybe? the less resistance, the current you will lose
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    Voltage drop is probably a more likely culprit than power loss, though I'd be surprised if 12' of wire is causing that big of a drop. Like mikevsgeek said, try using a lower gauge. Use a web calculator to estimate what your current loss is, and what gauge you'll need to bring it to a < 5' equivalent of your current wire.
    Mar 2004
    Miami
    Was thinking of that, but as it is the guage is matching the PC's standard guage... Which I believe is 10 or so. Thanks for the input..
    Mar 2004
    Miami
    Funny web calculator reads at 5 volt I have a max of 5772 feet before a drop ocurres...http://www.pelco.com/support/tools/wiregacalc.aspx
    Man
    Man is offline
    Low Bitrate Man's Avatar
    Nov 2003
    "This calculator is for 24 volt equipment only" -- From the linked site
    FLAC ppgt94's Avatar
    May 2001
    USA
    I have extended the 5v and 12v line from the Opus over 12 feet with 22g wire. Off that one (5v) wire I'm powering three different things. My slot-load slimlime DVD-ROM, the USB -> IDE converter, and a 4 port USB port that is full. I highly doubt your problem is a voltage drop due to wire length or gauge.
    May 2001
    USA
    Quote Originally Posted by Man
    So then wouldn't it just be half? If so, that's still a hell of a lot long than 15'.
    Mar 2004
    Miami
    Yeah something is harry, Because I can run my USB active hubs off the 5volt line just fine... However the dvd-drive is very sensitive... I cut the wire in 5 sections and same senario, anything passed 5 feet(give or take a lil) the drive has a hard time holding a spin when rotating the CD. BTW i verified and Im running 18 guage wire... I came from radio shack and they only have converters that drop to 4.5 or 6 volts. None were 5V. So i bought a 24 guage spindal and am going to give that a try...
    I will post my results. Thanks for input...
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Why are you using higher guage wire??
    Tidder
    Try RevFE
  1. Best remote DVD drive option
    By lookinco in forum General Hardware Discussion
    Last Post: 08-09-2004, 12:28 PM
  2. Slim Dvd Drive or Fat drive?
    By yunusyu in forum Input Devices
    Last Post: 05-28-2004, 08:06 PM
  3. DVD drive problems... Anyone have any ideas?
    By coachreed in forum General Hardware Discussion
    Last Post: 05-27-2004, 10:35 PM
  4. Slimline IBM DVD drive up for sale
    By mpattonm in forum General Hardware Discussion
    Last Post: 04-15-2004, 04:30 PM
  5. DVD Drive Question (slot loading)
    By breimann in forum Newbie
    Last Post: 03-09-2004, 06:20 AM
