Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: driver issues with usb to ide adapter
    May 2004
    I recently purchased a ide to usb adapter, no clue what brand, just came in box with no drivers. I pluged my dvd drive into it, and then into the computer, via usb 2.0 extension cable, and I just extended the power wires to the front of my car from the opus. when I plug it in, windows xp starts installing a "mass storage device" it installs it, and then in the device manager there is a little yellow question mark and it says the device can not be started. I have reinstalled windows, and tried everything I can think of in order to get it to work but havn't had any luck. I was just wondering if anyone else has any drivers for the usb adapter, or has some usefull information.
    thanks
    by the way the drive works fine when plugged in via ide. I ONCE got the drive to work(no clue what I did, but it started working) copied some files over, restarted my computer and then had this same problem.
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    I have had a similar problem when I plug my usb laptop hard drive into a front panel usb; on some machines they dont provide enough power to run my drive, it will try to load but says that it was not installed properly, and i get the caution thingy too. As soon as I plug it into a motherboard usb, it is fine. I think you need more power to the device (buy a usb hub that is powered for one example)
    2005 Ford Focus ST
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Could be the device has a problem. I would guess that if it came without drivers it's used. Yes I know win xp has built in support for stuff like that but it should have came with 98/ME/2000 drivers. Try it on a different computer too.
    Tidder
    Try RevFE
    May 2004
    I'm almost positive its getting enough power, I have a volt meter and the readouts are almost exactly the 12 and 5 volts required, I also don't think its used, it came in a brand new box, with an instruction manuel ect.
    FLAC ppgt94's Avatar
    May 2001
    USA
    Quote Originally Posted by jermkesler
    I think he meant power in the USB line. USB has 500ma inline and if you run it too far without a power hub it can cause data transfer issues.
    Dec 2003
    Portland, OR
    Quote Originally Posted by ppgt94
    Thats what I was getting at but I wasnt gonna argue
    2005 Ford Focus ST
    May 2004
    Is a 6 foot extension to far? I just don't understand why it worked once and never again
    Dec 2003
    Portland, OR
    6 foot is quite a bit for the power that a drive requires. Especially since the wire size is around 28-30 guage, maybe even smaller. Those extensions are great for very low power devices, but thats about it. I bet if you try to install it without the extension it would power up fine....and if so, then a powered hub is the easy way to fix it.
    2005 Ford Focus ST
    May 2004
    alright, I'll go try that now, how would I go about powering the hub, and how much do they cost?
    May 2001
    USA
    I'm pretty sure 6 feet isn't too much. USB is good for at LEAST 10ft (some would argue 16ft) before you may run into problems. Besides now that I think of it the drive already has seperate power from the Opus going to it. I have a similar setup. I run power to the front from my Opus to a slimline drive and gutted a IDE -> USB 2.0 drive enclosure for my adpater.
  1. Squarish slimline/notebook CD/DVD to IDE adapter?
    By tom61 in forum General Hardware Discussion
    Last Post: 05-29-2006, 02:00 PM
  2. USB 2.0 to ide adapter, anybody got one of these working
    By Batmanatthenewb in forum Input Devices
    Last Post: 08-16-2004, 03:23 AM
  3. Belkin USB to PDA adapter
    By MatrixPC in forum General Hardware Discussion
    Last Post: 07-28-2004, 01:00 PM
  4. WTB: Laptop dvd drive to ide adapter
    By leenas in forum Classified Archive
    Last Post: 06-30-2003, 09:04 PM
  5. USB Sound Adapter
    By allenruble in forum Classified Archive
    Last Post: 12-09-2001, 08:05 AM
