Results 1 to 10 of 12
Thread: Anyone built an Epia PC behind a toyota Dash?
    FLAC Skraggy_uk's Avatar
    May 2002
    Warrington UK
    I've got a Celica GT4 1990 ST185.
    The stock design is for a double din, with a 1 din headunit and spacer/tray fitted to most euro models, with only the JDM versions using double din.
    Now I want to lose the Tape Headunit that is there, and if possible fit an SP7 screen behind the space where the double din would normally go.
    I'm just wondering if, with a cage/frame made up in pop rivetted angle and bar, wether I could fit an Epia M10K, an Opus 150watt, a 3.5" HDD, a D-Link DRU, and maybe slot DVD where the cup holder go.
    I realise I would need to make an adaptor for the D-Link antenna, and sort an Amp out, probably below the seat, unless I could find a small 4 channel amp that will go under the PC inside the centre console, so that I can tap into the standard speaker harness through an adaptor, and arrange a remote feed for the amp and power antenna.
    Audio power isn't an issue here, it is cleaness of install. Standard speakers sound OK on FM, and don't distort when I turn it up to the volume I like to use, so I will keep them for now. Don't fancy starting to pull out seats and lifting carpets.
    4x4 in a turbo stylee.
    Variable Bitrate streetknight's Avatar
    Dec 2003
    in my supra theres enough room for my m900,2.5hdd,slim dvd,opus150w, and all the wires. just took it out. to glass another 7"xga screen so i would have to say yes there is enough room back there.
    May 2002
    Warrington UK
    Quote Originally Posted by streetknight
    Ah fantastic, what I'm hoping to do is make up roughly a double din sized box (maybe slightly deeper and hopefully set back a little further if I can), that fits into the space of the standard JDM double din.
    Then hopefully mount either a Lilly or SP7 TFT on the front of that, on a swing and drop mechanism (little like the sliding side door on a minibus/minivan) so the front can drop down enough to get to the slot DVD, and lock back up again with either a magnetic or hook/press catch.
    Variable Bitrate ryuandwings's Avatar
    Nov 2003
    TN
    here is what I did to my double din.
    Using stock stereo brackets and aluminum bars.
    This is not Toyota, but it can't be that much different.
    May 2002
    Warrington UK
    That looks very similar to what I hope to achieve. I know I'm not likely to get the screen totally flush mounted with what I plan, but that won'y be too much of a biggy in my case.
    Dec 2003
    something u might want to think about trying, is getting some old brackets and 4 strips of metal and making the size of the radio installed. and fiberglassing the bottom and top and thats pretty much the whole box u would need the mobo on the bottom and the opus can go in the back. the monitor can be secured to the case. some fans and ur all set. ill so start mines for the supra. ill take a few pics here and their
    Jun 2000
    NYC
    Anyone worried about airflow/heat issues. There was someone at the long island meet who had one in their glove box, and during hot days in the summer, the carpc was unusable. I keep mine currently under my passenger seat and fortunately I have an acc vent under there to keep mine frigid.
    Dec 2003
    i thought of that but if u add a good fan to take air from out and push it to the other side of the dash lest say the pass. u should be fine. my non technical thought
    Best Technique In Life Is Having No Technique
    ONE DAY I WILL LEARN HOW TO USE THE COMPUTER THE RIGHT WAY.
    Jun 2003
    Chicago
    I have a 93 ST184 convertible and I'm very familiar with how much space you have 2 to 2.5 DIN if you take out the cupholders. I do not recommend trying to fit everything in that little space. Keep in mind you still need space for cables to conect to the mobo. I installed my system in the glove box on my first install attempt but ended up opting to have the PC in the trunk which has worked out very well. I recommend installing a USB2.0 slim slot load dvd drive and possibly a memory card reader in the unused DIN slot.
    May 2002
    Warrington UK
    Cheers EBJUSTIN.
    I reckon, with a little work, and inguity I can get it in there easily (time to grab he dremel, the tin snips, and the pop rivetter), with the screen appearing semi flush fitted, but able to slide out and down to allow access to the DVD.
    I did manage to get an Epia, a 3.5" HDD and a full sized 250WATT ATX PSU + all the cables into the lower box of a Saab 900, which is narrower, but deeper than a standard double din.
    Cup holder will probably go, as I never use them, I find that my hand hits any bottles/cups in there but a screen in operating position won't stick out so far, and if needed I'll get a clip on one that goes on the door card or console.
    Just had a look at your install page, looks pretty good.
  1. For Sale for all you aussies. Complete mp3 car pc
    By Holden__V8 in forum Classified Archive
    Last Post: 04-09-2005, 05:30 AM
  2. dash PC
    By Dexter172 in forum LCD/Display
    Last Post: 06-17-2002, 09:01 PM
  3. no box pc??!! built into keyboard!
    By RaZor in forum General Hardware Discussion
    Last Post: 12-08-2001, 04:58 AM
  4. FS: Casio EM500 Pocket PC / 800mhz Desktop PC / Misc
    By gguy in forum Classified Archive
    Last Post: 10-07-2001, 08:00 PM
  5. pocket-size PC...would fit in dash
    By Meatballman in forum General Hardware Discussion
    Last Post: 04-19-2000, 03:33 PM
