Results 1 to 10 of 11
Thread: pci extension cable, pci right angle
    IQ < 70
    Mar 2004
    is there a way to make your pci cards lie flat instead of at a right angle to the motherboard? i want to make 4 pci slots lie flat instead of at a right angle. is there any sites that have these, maybe like a ribbon cable, that connects to the cards?
    Jun 2003
    Yes, I am too locking at this option, they are called pci flexible riser cards, comes in various lengths.
    /L-O
    FLAC john1701's Avatar
    Mar 2004
    Fort Myers, Fl
    CAR:2001 Ford Crown Victoria
    PC: Acer EEE 900HA with Win7 with CF 2.0.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
    Screen:Xenarc 700TSV
    The Florida Meets Thread
    Variable Bitrate Curly_cat's Avatar
    Jun 2004
    Ipswich, UK
    Theres a good range of riser cards here .
    : Jetway J7F2 1.5Ghz Mainboard : Cubid 3688 : CarNetix CNX-P1260 :
    : Netgear 802.11g PCMCIA : 2 x LinITX 7" Screens :
    : BU353 USB GPS Mouse : Panasonic UJ845 DVDRW :
    Mar 2004
    Marietta, GA
    dim-8... just be careful about which riser card you get. Some are 32bit, some 64/just make sure you check that it will work on the board you have. Many of these don't work with the epia mini-itx boards!
    Jun 2004
    Ipswich, UK
    Quote Originally Posted by dim-8
    Quote Originally Posted by LekanB
    Point me at the mini-ITX board with 4 PCI slots!!
    those little cards are expensive for just wires. by the way i like you mgb i own a 76 mgb myself
    FLAC Skraggy_uk's Avatar
    May 2002
    Warrington UK
    OK, well, was just about to start a new post, but adding here seems is both helpful and useful.
    I found this riser card. It's for Epia boards, but looking at it, it doesn't say which way it is supposed to face, and wether it lays the cars over the motherboard, or effectively lays them the other direction away from the board (yes I know it says away from, but I'm not sure if that is just bad wording) almst doubling the width of an Epia?
    If it lays over the board (which I hope), do those measurement look like they will clear the IO backplane when it is fitted over the ports?
    I'm looking to try and assemble a 2 Din box behind the dash, with the screen dropping down slightly on a hinge or rails and a spring to allow access to a slot DVD rom.
    4x4 in a turbo stylee.
    Jun 2004
    Ipswich, UK
    Quote Originally Posted by Skraggy_uk
    That riser faces away from the mainboard.
    May 2002
    Warrington UK
    Quote Originally Posted by Curly_cat
    Bugger, that is my plan knackered then. Guess I will have to find a USB WiFi card should I choose to add it as well as an FM PCI card.
  1. VGA extension cable
    By Bxscig in forum LCD/Display
    Last Post: 07-29-2004, 10:33 PM
  2. Extension cable for Deluo serial Gps?
    By Bob0_o in forum GPS
    Last Post: 06-27-2004, 08:04 PM
  3. PCI slot extension
    By alienjj in forum General Hardware Discussion
    Last Post: 02-08-2004, 02:35 PM
  4. ISA extension cable?
    By mtmsol in forum General Hardware Discussion
    Last Post: 02-21-2003, 03:37 AM
  5. LCD extension cable ThinkPad 560
    By hakan in forum LCD/Display
    Last Post: 03-22-2002, 07:36 AM
