Results 1 to 2 of 2
Thread: help, brand new epia M10000 not booting!
    Central NY
    I finally got my board today, so I plugged in my ATX powersupply, shorted the power button pins as I don't have a case for it yet, and nothing happens. Everything is plugged in, tried another powersupply, powercable, the screen comes on, so I know the surge protector is good. Nothing happens, not even the fans on the power supply spin up. I didn't see anything in the manual about having to disable a jumper first or anything like that, is this a common issue or is my board DOA?
    edit: it's working now, didn't change anything. Damn gremlins!
    Oct 2003
    I had this problem too. First, check your Ram to make sure it's compatible. Then, go back and check your ide cables as well. Try to boot with just a hard drive first. If that doesn't work, try ANOTHER power supply. It seems to be very picky about which ones it will work with.
    Good luck!
  1. Epia M10000 VGA problems
    By Dluvr22 in forum General Hardware Discussion
    Last Post: 07-10-2005, 07:38 PM
  2. FS: EPIA M10000 Mobo & 512Mb PC133 SDRAM (Brand-New).
    By buildfromscratc in forum Classified Archive
    Last Post: 09-20-2004, 09:32 AM
  3. Replies: 4
    Last Post: 07-06-2004, 10:52 PM
  4. Via Epia M10000 random reboot
    By patchan in forum General Hardware Discussion
    Last Post: 06-13-2004, 05:37 AM
  5. v10000 epia vs m10000 epia
    By traitorhound in forum Newbie
    Last Post: 11-27-2003, 10:19 AM
