Ground the supply to the car. That should cure it!
Ive finnaly got the beast running the car, but there is a humming noise comming through. Right now i have it running thru the ciggarette lighter to a tripplite 300 watt inverter. Would wiring it to the battery help? any other ideas?
The hum is constant, and only changes if i turn up the volume.
For all those that want to stop buzzing and many other annoying noise problems, do it right the first time.
1)Run the power for the inverter or DC-DC direct from the battery.
2) When running audio cables (i.e. line level audio), get them as far away from any power source as possible.
3)As was said in the above message, ground EVERYTHING. Lets not get dumb here, I'm not talking about power lines and other assorted items that should be isolated from neutral electropotential. I'm just talking about the case and power supply. One or the other should be fine. If you are using an inverter, it dosent hurt to make sure that there is a good ground connection as well.
4)When building a case for your system, be sure to make it out of metal or at least line the case with a metal barrier that is tied to ground. This will eliminate the EM noise that is put out by the computer that causes so much trouble.
I will not be held accountable for any damage done to your car, computer, or anything else that may burn, elplode, melt, send sparks flying everwhere, or anyting else that goes wrong. Do everthing at your own risk. That is all.... ( I just had to put that in to scare some newbies) Have fun!!!
Monger
ICQ-7207702
Monger
ICQ-7207702
UPDATE: I moved farther north. Now its even too cold for the deer; only moose now
