Results 1 to 5 of 5
Thread: Asus Pundit Power On Button
    Low Bitrate PHiLiSO's Avatar
    Oct 2003
    detroit
    Hello fellow mp3car friends. I am wondering if anyof you out there uses the Asus Pundit as your car pc, and if so if you have extended the power button on the front bezel. Its not like your normal switch that just plugs into the motherboard, the button is actually soldered on, and you cannot remove the moptherboard from the case. If anyone one has an idea, or a solution please let me know.
    How in the world would you put the special AirPort card in a PC? Mine is a Mac anyway but it's too old to AirPort. I just use a zip drive to transfer.
    Variable Bitrate darkhalo's Avatar
    Puerto Rico
    hahhaa this was a bit trickky... if you look at the button from the top you'll see a tiny peice of metal exposed... i used my soldering iron to melt the plastic around it abit and i was able to solder on a small wire... at wire has the 3.3v on it. all you have to do it ground it and the pc turns on.. ill try to get pics maybe this weekend if you still need help.. Good luck
    Carputer: 2.8Ghz P4, 512 RAM, 120gb HDD, WIFI, TV tuner, CDRW/DVDROM, Slot load DVD in front.
    Screen: Lilliput 7" touchscreen (Custom made Carbon Fiber Screen Enclosure)
    S2000 Carputer
    Oct 2003
    detroit
    Yes pics would be great! After I get the power switch extended my system will be damn near complete, well we all know its never complete. Soon as I get the switch extended pics of my system will come.
    I just soldered onto the 2 pins coming out from the button going into the mb and ran that wire to my on\off controller. The 2 pins are the same as the two pins that a power button would normally connect to the mb with. It's just a little hard to get to the pins.
    - Kyle
    Oct 2003
    detroit
    so it dosent matter abou + and -? I just solder to extended wires?
    a pic would really help. thanks guys.
  1. New product - PC Power switch with wired remote
    By hd54321 in forum General Hardware Discussion
    Last Post: 03-08-2006, 11:48 PM
  2. OPUS plus power button
    By The Grinch in forum Power Supplies
    Last Post: 07-25-2004, 02:55 PM
  3. mobo does not support resume on power loss
    By ashbosh in forum General Hardware Discussion
    Last Post: 05-18-2004, 10:49 AM
  4. PW-70, ITPS and Power Button
    By dug1967 in forum Power Supplies
    Last Post: 02-13-2004, 10:14 AM
  5. getting an odd motherboard to power on
    By karmann in forum Power Supplies
    Last Post: 11-28-2001, 06:27 PM
