Results 1 to 10 of 12
Thread: P4-ITX Mainboard
    Denmark
    P4-ITX Mainboard
    Do anyone know this board ??? The only ITX P4 board to under 200$ I've seen earlyer, is the Insight board. But I think i read some where in this forum that it had alot of problems with the Opus ???
    This board is also build on a Intel 845GV chipset, instead of the VIA P4N266 chipset. And as IDE2 channel the Intel board has 44-pin header, as i recall that's for 2.5" Harddrives ???
    CarTFT writes "Pentium 4 2.4GHz (256KB) with 256MB DDR memory +5V: 3.29A; +12V: 4.83A"
    The plan for my sytem would then be:
    The P4-ITX Mainboard
    My 2.2GHz P4 Mobile CPU (30watt)
    512MB Ram DDR PC2700
    HDD 40GB 2.5" 5400rpm/8192kb cache
    Panasonic Slot load DVD/CD-RW
    Could i possibly run this on the Opus 90watt, or am I forced to use the 150watt ???
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Just to be safe I'd say the 150watt. 90 watt is gonna be pretty close to what your computer will be using. On the opus that's a 90watt MAX output correct?
    Tidder
    Try RevFE
    Constant Bitrate CHUPACABRA's Avatar
    Mar 2004
    G'ville S.C.
    Thumbs down
    Do you have a make model # for the board? That would help cause ther are many p4 itx boards out!!!!
    2-15" ILO lcd w/DVI
    6800 gt Duel DVI out
    p4 1.6ghz flex atx board
    1gb 400 ram
    120gb(2-60gb raid) sata hd
    2-60gb hotswap
    WIN2K Pro SP2
    M.A.M.E. w/2,300 games
    CARPuter info
    Feb 2004
    NYC
    Quote Originally Posted by CHUPACABRA
    Um... he just mentioned the board.. It's the Insight P4 ITX.. There's only 1 model from there.
    I have that board. I think I was the one that mentioned the problem with the OPUS.
    MY CPU is a P4 2.8c w/ 1U size Heatsink/Fan
    Full Size HD and Full Size DVD-ROM
    512 mb ram
    The problem I had with OPUS is that it doesn't do standby properly. Opus contacted me and tell me to call them, they may have a solution. But I'm too busy at the moment to work with my carputer, so I've been putting it aside. Hibernation is fine, regular startup and shutdown is fine. If you're not planning to use standby at all. There is absolutely no problem for you.
    Oh, I have the 150watt version, it never hurt to be prepared, you never know when you'll going to need that extra 60watt.
    Variable Bitrate NoPistonPC's Avatar
    Boston
    I have an Insight P4-ITX as well.
    The IDE connector is the normal big kind. It works with the standard connector for 3.5" drivers. If you want to use it with a laptop drive, you'll have to buy an adapter.
    Opus 90W will definitely not be enough. The Opus 90W puts out 2.5A on the +12V rail. This is about 30W and your P4 will need somewhere between 60-70W. Even an Opus 150W (which puts out about 60W on the +12V rail) may or may not be enough depending on your processor. I use an Arise MPD-810H which puts out 72W on the +12V rail. It has worked fine for me so far.
    You might also want to consider getting a 1U CPU Fan like the Dynatron DC1206-BM. The Intel one that comes with your processor is way too big.
    1994 RX-7, EPIA P4-ITX w/ Celeron 2.4 Ghz, Arise PSU, Xenarc 700TSV (new model)
    Denmark
    Hmmm sorry.... I forgot an important thing .... The link to the board ...
    http://www.cartft.com/carpc/catalog/il/328
    It is'nt the Insight board, and i don't know who makes it, but it looks pretty sweet....
    It's an P4 Mobile CPU at 2.2GHz I'm using, so it doesn't need that much power... It's rated at 30watt, and not 60-80watt like an normal P4 CPU
    I alrady lokked at an 1U cooler -> http://www.cartft.com/carpc/catalog/il/330
    How much bigger is the 150watt dimensions, than the 90watt.... ???
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    That is darn near $200 USD.... Yikes that is a bunch of $ for a mainboard.
    TruckinMP3
    Read the FAQ!
    Feb 2004
    NYC
    Quote Originally Posted by wanjer
    Becareful on which 1U heatsink fan to go to. You wouldn't want a jet engine sound inside your car. That is the main reason I also chosen the Dynatron. The noise is not as noticable.
    I'm not entirely sure what the dimensions on the 90 watt PSU, so I can't help you there. But I can certainly say the 150 can handle my P4 2.8c + Full HD + Full DVD. And the PSU fits in the palm of my hand.
    I don't know much about that board, so I can't give any comments on it.
    Feb 2004
    NYC
    Quote Originally Posted by NoPistonPC
    NPPC, have you figure out how to put it in standby yet? I really missed standby. Nothings beats 3 seconds from iginition to song playing.
    Mar 2004
    New Jersey
    I have this motherboard... and i love it.. I used the 44 pin ide for my 80gig laptop harddrive.. it eliminated the need for extra power wires running around for a full size hd. I am using firewire for my slim cdrw/dvd drive.
    As far as the powersupply.. i suggest you run a 150w. The P4's seem to draw a lot of current. I think just about the max of the 90w psu.
    the motyherpoard boots up fast.. POST is quick, it also has digital in or out. The graphics max out at 8megs of ram but it can handle the winamp vis with no problem.. (Gueiss) however i have not tested milkdrop yet.
    I like the fact that it has Firewire with an extra header and USB 2.0 with an extra header. It also has Irda headers.
    -Jack
    2006 Chrysler 300C AWD
    Samsung Galaxy Tab In dash
  1. Travla C137 & OPUS & ITX P4
    By craigyb in forum General Hardware Discussion
    Last Post: 11-13-2004, 10:51 AM
  2. P4 ITX popping during power up only
    By satmanuk in forum General Hardware Discussion
    Last Post: 05-30-2004, 12:15 PM
  3. Bargain!! Via Epia Nehemiah 1ghz Mini Itx Mainboard
    By dave0109 in forum Classified Archive
    Last Post: 05-26-2004, 07:40 AM
  4. FS : ITX P4 Mainboard and DC/DC Converter for Travla C134/C150
    By VooDoo1999 in forum Classified Archive
    Last Post: 03-05-2004, 03:15 AM
  5. p4 ITX
    By ricoks in forum General Hardware Discussion
    Last Post: 10-16-2003, 07:01 PM
