Results 1 to 10 of 19
Thread: what in the blue hell did i do??
    Low Bitrate odleon's Avatar
    Atlanta
    well for some reason the carputer decided it wasnt trying to get finished so now it threw me a curve. for some reason, it says operating system not found. it will load the little blue "HP" screen like always but after that, it goes black and syas OS not found. it was working fine just last night,havent changed any software. just changed the hdd cable fome the reg ide to a round one and added psu to mb extesion cable. what the hell did i do??? what can i do to fix it(i have the recovery cds but it wont boot up from cd.) what can i do to fix it??? did i fry my hdd???
    Super Moderator xBrady's Avatar
    USA
    Quote Originally Posted by odleon
    What does it do when you try to boot from CD? If you can get that to work and have your Windows CD then I would try running a repair on windows (works pretty well for most problems like the one you are having). Did you try switching back your cables?
    Installed.
    -GPSSecure- - GPS Tracking
    Mar 2004
    Vancouver, BC, Canada
    Go into the Bios and see if it finds your HD.
    Atlanta
    thing is it will let me into bios when it feels like it and last time i was in there, it did detect it(earlier today).when the blue screen is up, i try pressing f9 or f11 and nothing. and i went back to the original cable.
    Mar 2004
    try pressing delete
    Atlanta
    same result
    Maximum Bitrate falconey's Avatar
    Feb 2004
    Atlanta
    Check your jumper settings...go back to original jumper settings and original cable and then post results. What stands out to me is you changed to the rounded cables. If this cable has two connectors it's possibly the jumper settings on the hd. In working with on my carpc I've found that the older system I'm using is quite particular about cables and jumper settings.
    Atlanta
    the connector for the hdd is supposed to be which one?? i have p1-p5. i had them labled but the lable fell off.i have it on p2 now. the round cable to the mb is the same as the original, just round. by the way, im in Atl too
    In a barn
    just pop open the case and find any and all wires and make sure they are all pushed in the right way.
    When in doubt, moo at things.
    Atlanta
    i dont have a case, and yes all the wires are in all the way. ill try more tomorrow as it started to **** me off today.
  1. Blue Screen O' Death. (MOBO Switch)
    By cadence117 in forum General Hardware Discussion
    Last Post: 08-20-2004, 08:31 PM
  2. Blue screen of death...
    By cadence117 in forum General MP3Car Discussion
    Last Post: 06-14-2004, 08:24 PM
  3. 24G Blue Empeg With Tuner 2 remotes (Re-Post)
    By belezeebub in forum Classified Archive
    Last Post: 03-07-2004, 12:00 PM
  4. Nokia 3650 Bluetooth? I'm a newbie with blue tooth
    By churnopol in forum General Hardware Discussion
    Last Post: 05-24-2003, 08:08 PM
