Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: what happened to mp3ondemand?
    Jan 2001
    baldwin pk., ca
    Question what happened to mp3ondemand?
    anyone know what happened to mp3ondemand?
    i've been waiting to buy an autoshutdown unit from them for the longest time.
    is there any other autoshutdown/autostart units out there?
    Mar 2000
    Washington DC
    Post
    Just get an IRMan..
    You can use the remote to shutdown windows.
    Shutdown units seem like such a waste of money in my opinion.
    Aug 1999
    Upper Marlboro, MD 20772
    Cool
    It is a waste. And for God sake ppl u don't need auto shutdown crap.
    abcd-1
    Author of CobraI and CobraII.
    For more information on the COBRA Application's please visit the link. For the latest or updated info on CobraII please click on the link. Get new updated files for CobraII here. ftp://picturesictures@128.8.187.126/d:/newdlls
    You can contact me on AOL instant messenger....nick is Cenwesi
    Webpage comming soon!
    abcd-1
    Maximum Bitrate gizmomkr's Avatar
    Dec 2000
    Smyrna, Ga, USA
    Post
    How can you say that !
    Dont you get the idea of the shutdown.
    You go into the store, you think you will be in and out in 5 min. you leave the thing running. You get sidetracked, you take an hour, then you decide to walk across the street, eat and see a movie. you get back - your car bat is dead.
    People forget to lock there doors, put on the parking brake, turn off there lights. Im sure there are plenty of people that forget to turn off there computers.
    Or, say you have an ATX system with inverter. you power off the system, but the inverter is still running. The inverter alone will drain the car bat in a mater of hours.
    The reason I want a shutdown unit is saftey and a mater of convience. I dont want to have to worrie about it. I can get out of the car, and *know* if I take to long, or forget , the computer will take care of its self.
    Gizmo-
    Techonlogy on Wheels
    http://www.hjnetworks.com/car
    Jan 2001
    baldwin pk., ca
    Post
    i was actually interested in the autostart function.
    i'm having a hard time trying to figure out how to turn on the computer when it is in trunk.
    any help is greatly appreciated.
    Live and Kickin'
    Arby's Avatar
    Dec 2000
    Houston
    Post
    If it's an ATX, there's a setting in bios to allow you to tell the computer to "turn on when power applied."
    Do this in combination with a power switch in the car to turn on the inverter.
    Switch turns on inverter, computer comes on when it gets power.
    http://mp3box.2y.net
    Aug 1999
    Yorba Linda, CA
    Post
    There are about 5 different ways you can get an ATX motherboard to power on (depending on the BIOS):
    1) The POWER button! Most ATX boards have a 2-pin header for a momentary power switch -- you can easily extend this to the front of the vehicle and use it. You can also extend the HD/PWR/ACPI/LAN LED's and the reset button to the front, which is kinda cool
    2) A hotkey (ALT-F1, etc.)
    3) A password (when the right sequence of keys is hit on the keyboard, it turns on) -- you could easily set it up to work just like an ATM machine -- you enter your PIN on the keypad and the PC powers up!
    4) When power is applied -- you can set up the BIOS to turn on the PC as soon it gets power from the 110VAC plug.
    5) WOL (Wake on LAN) -- most ATX MB's have a 3-pin header that has +5V, GND, and WOL pins. If you connect a pushbutton between GND and WOL, you can power up that way.
    6) Alarm setting (some MB's don't have this) -- you can program with special software or through the BIOS for your PC to "wake up" at a specific date and time. For example, you could write an app that would allow you to have your PC wake up at a programmed time, record a radio program through line-in, and then shut down.
    For shutdown, if you have a DC/DC ATX supply you are fine, since when Windows (or Linux) shuts down, the motherboard instructs the PSU to turn itself off.
    For an inverter + ATX combo, you may have to get creative and wire a relay to the computer's +12V output and a momentary switch to the vehicle's +12V so that you can press the button and have the PC start, and when it shuts down and loses the +12V output, the relay disengages and the inverter cuts out. This would take some diodes and possibly some other components, but it would work. If people are interested I will whip up a schematic for this.
    Sorry for the long post -- I wanted to clear up some things!
    [This message has been edited by jjohnson (edited 01-19-2001).]
    Jason Johnson
    Yorba Linda, California
    http://www.m2pc.com
    M²PC Phase IV - *** PENDING ***
    Aug 2000
    Abbotsford, BC, Canada
    Post
    Ok... I gotta ask about #3...
    How do you get it to accept a password as a wake-up call?
    I'd rather ask here than at work - heh heh heh LOL! LOL!
    ~m
    PII 266, 512 MB RAM, 10 Gig, 36x CD-ROM, 16x DVD, DeLorme GPS, 5.6" LCD Screen, Dschmidt power controller, Keypower ATX DC-DC Supply, PowerAmp Macro controller, Dauphin mini-Kbd.
    Sony Head Unit, Sony Unilink input selector, rear deck Kenwood 6x9's, stock door spkrs... All in my '96 Civic, of course :}
    BC ROCKS!!!
    Jan 2001
    Pensacola, FL
    Post
    A bunch of the turbo guys use "Turbo Timers" on their cars. Basically, when you shut the key off, the engine stays running for a predetermined amount of time (10-12 minutes normally) to let the turbos cool down. You could always buy one of those so you wouldn't have to worry about shutting it down. If you're not back in the time frame, the system shuts down.
    I've also heard that some alarms have this function built in. Press the Valet key sequence on the key fob and it will run without the key for a set amount of time.
    My $.02
    Oct 1999
    CA, USA
    Post
    I've been selling these for well over a year.
    Surprised no one else chimed in to let you know about it.
    http://www.dschmidt.com/autooff.html
    It is really a smart Powerup and Powerdown controller all in one. It'll solve your problems of starting up your ATX motherboard too (if your bios doesn't do it automatically).
    Dave
