Do you still have that VB script?
I want to use that script to automatically lock my door and arm the alarm before going into hibernation.
Originally Posted by Enforcer
I found a little vbscript that detects hibernation, and I modified it to do some stuff for me.
My post is only a second or two, and resume from hibernation (to music playing) is less than 15 seconds, including post.
I played around a bit with bootvisBootVis , and it did seem to help a little bit, but it wasn't exactly a scientific test.
Originally Posted by zPilott
Where? where?. Gimme gimme![]()
Yea, I'm going to try out BootVis later, just found it
I found a notebook drive RAID! Won't slow down post, and speeds up disk access.
http://www.arcoide.com/products/pdf/microraid.pdf
I think it's just something to add to my wish list for now though.
Same here would lve to see this script ive searched for months for thisOriginally Posted by zPilott
Co Develper of A.I.M.E.E Automotive Intelligent Multimedia Entertainment Engine
www.aimee.cc
I wrote a small app to do this before.. but it only kills Winamp processes:
Small App: WinampHelper
I can try dig up the source code if you like.
Btw, you can also speed up resume from hibernation by defragging your hibernation file. I don't know if standard windows defrag does this, but tools like Executive Software's Diskeeper will do it.
possible fix, err, bandaid for usb gps/touchscreen suspend/hibernate woes
here is the script that I am working on.
On XP pro try GPEDIT.msc ....computer config/Admin template/system/Logon and enable Always use classic logon and disable Dont display the getting welcome screen.. seems to speed up resume from Hibernation you get a different log off menu which includes Hibernate & you loose the getting started screen no bad thing.
