Results 1 to 10 of 19
Thread: Any way to speed up the resume from hibernation?
    It's not really that small...No, seriously. judoGTI's Avatar
    Feb 2004
    Florida
    BESIDES getting less RAM?
    I was just curious, maybe reducing the virtual memory size? Any other idea's? I resume in about 30 seconds but its always fun to try and speed things up.
    '02 GTI
    [Routis '04] [Opus 90W] [160GB Maxtor HD]
    [Lilliput 7" TS] [VIA M10000] [XMPCR]
    [512MB RAM] [Custom housing]
    [Deluo GPS Mouse] [E-MU 0404 Soundcard]
    Progress Meter: [==============|] 99.9%
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Uhm, Ultra 320 SCSI RAID with 15 drives?
    Maximum Bitrate zPilott's Avatar
    Jul 2004
    Austin
    how long of that is POST?
    the scsi card I use at home (yeah, its old) takes 10 seconds to start up by itself.
    I bet that you can disable services that you dont need, and hardware you dont use and show some improvement.
    take a look at http://www.blackviper.com/ for info on unneeded services.
    If you can, disable any devices that you don't use (in bios)
    You could always try linux
    |V1 Virtual Display|
    Hard work often pays off over time, laziness always pays off right now.
    Jun 2003
    Atlanta/Augusta, GA
    Ultra 320 SCSI RAID with 15 drives will probably be much slower. The RAID bios will initialize each drives and any arrays before loading or resuming the operating system.
    To gain a bit more speed, try tweaking the bios / POST. You can disable memory checks, and turn off IDE channels and other devices that are not being used. Instead of auto detecting the harddrive or other devices, see if you can specify them manually. You may lost a bit of plug and play functionatily in trade off for quicker boots. Search google for more information.
    Sep 2003
    Elgin, IL
    well there's quicker posts and then there's quicker windoze boot. how to reduce the time AFTER the post and during the windows load?
    Jun 2003
    Atlanta/Augusta, GA
    When resuming from hibernation, I'm don't believe windows loading play a factor. Instead it only involves restoring the state of your ram from disk. To speed this up, having less ram or a faster drive may help. The only other factor is bios POST time.
    I searched google for some more information on xp hibernation (os hibernation in general) and tweaks, but I came up empty handed. I'm curios to find out what steps are necessary for hibernation / unhibernation at the OS level.
    Jan 2003
    Ruston, LA
    Quote Originally Posted by tejesh83
    Boot system to minimal state. Load image. Transfer control. Enjoy.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Does Windows send out any kind of flag that can be picked by programs when a PC is about to go into hibernation?
    and also any kind of flag to say it's just come out of hibernation
    Mar 2004
    Florence Yall, BFKY
    WM_POWERBROADCAST with a WPARAM of PBT_APMQUERYSUSPEND, then PBT_APMSUSPEND, and when it resumes PBT_APMRESUMESUSPEND.
    All the drivers have power functions that are called so they can perform any state saving and restoring that they need so having less drivers may speed things up slightly, but it's hard to tell how long that part actually takes.
    Super Moderator xBrady's Avatar
    USA
    Or just use standby.
    Installed.
    -GPSSecure- - GPS Tracking
  1. Problem with interrupted resume from hibernation with XP
    By Mastiff in forum General MP3Car Discussion
    Last Post: 01-25-2005, 05:46 PM
  2. GPS Hibernation resume
    By BOND007BE in forum GPS
    Last Post: 09-30-2004, 04:27 PM
  3. WinXP Hibernation Problems
    By jeremyp111 in forum Software & Software Development
    Last Post: 09-16-2004, 10:31 AM
  4. Should GPS stay locked thru hibernation?
    By technopsych in forum GPS
    Last Post: 08-04-2004, 01:30 PM
  5. Replies: 2
    Last Post: 11-25-2003, 11:50 PM
