Results 1 to 10 of 19
Thread: Flash OS
    Variable Bitrate BiohazrD's Avatar
    Katy TX
    Flash OS
    I have seen that some people have their OS loaded onto a flash card, thus giving a extremely fast boot time (DriveSoft uses this as well). How do you do this?
    Quick! To the Popemobile!
    Rochester, NY
    Just put the flash card in and install the OS on it. Assuming you're using an ITX MB with built in support it should show up as a drive.
    89 Mustang (Autox, road race, and cruiser)
    93 Escort (Daily Driver)
    84 Dolphin RV (Soon to be Carputer Heaven)
    Maximum Bitrate Change's Avatar
    Aug 2004
    California
    Make sure in Windows to disable the swapfile on the flash disk, or in linux disable the swap and use the no atime option in your fstab. This will prevent excessive writes to the device (flash devices have a limited number of write cycles in their life).
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    You can also get IDE adapters if you don't have a compactflash et al port on your motherboard, i.e.
    http://linitx.com/index.php?cPath=39...43406c9ba7fb08
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
    Maximum Bitrate Don 944 LA's Avatar
    May 2004
    San Diego / Los Angeles
    Just like everyone is saying.
    I'm going to be using a 512mb CF card ( $40 EvilBay )
    Instead of using Win XP, I'm going to be using XP Embedded. XPE is a snapshot of just the parts of the OS that you need, so you have a very small OS footprint. I will also have a laptop drive for file storage. If either breaks, it's a quick change without having to reload and tweak.
    You can also here, as there is allot of talk about that type of setup.
    I am wondering if I partition the CF Card and have the OS on one partition, then the files that change on another ( like settings ini and playlists etc...). I believe that the solid state CF cards don't have a write limit, just the CFII of Micro-Drives.
    Can anyone give info on those questions ??
    Sorry if I hijacked thread.
    Don
    Variable Bitrate brooksware2000's Avatar
    May 2004
    Minot AFB, ND
    Quote Originally Posted by Don 944 LA
    Don
    Not all correct. Compact flash cards do have a write limit. CF type II cards are like microdrives which have platters in them like HDD. Most likely, compact flash cards have a write limit of 1-10 million write cycles. Again, the best option, if using xp/linux is to turn off the swap file. For our applications, the swap file should not impact the overall performance much since we are using the system for a limited application. This option will work best if you have a lot of ram since operations will swap in ram and not to the drive.
    Check out my hopefully useful site...
    www.hobbybotics.com
    It's still under design but it is functional
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    Also worthy to note, while flash memory will have next to 0ms access times, the max transfer rates on flash is only 9~10mbs, which is much slower than a modern ide drive. So it's not necessicarily the magical superboot solution people make it out to be.
    -Nick
    _____________________________
    Monthly MP3Car Chicago Meets
    www.mp3vw.com Last updated: 07/07/2008
    May 2004
    Quote Originally Posted by MP3DUB
    will that be the case in a mall footprint OS.. by the time an ide spins up etc.. couldn't the OS be loaded already by flash ..
    I'm still in assumption mode, no fact to back it up
    Jan 2002
    Chicagoland, IL
    An ide hdd has spun up to operating speed before the post process finished, which isnt even to device initialization, which is still before booting, so both flash and ide will be primed to go by the time the system is ready to start booting an os. Win98Lite (or something similarly small) would probably see the greatest results from being loaded from flash, as there are still numerous files that have to be loaded to ram, but the footprint of those files are tiny compared to xp.
    -Nick
    Constant Bitrate NOS TANG's Avatar
    Mar 2004
    OH USA
    I have been running XP Pro on a microdrive for some time now. Biggest problem I found is that XP doesn’t like the “C” drive being a removable media. Page file is off but still finding a lot of things that are not working correctly. Trying to work out these issues and a way to convince XP this is just another ATA device. Was thinking maybe XP embedded might work better. I posted a question about this here: XP on CF II Drive
    Anyone who has seen this before please comment..
  1. compact flash raid
    By B3AND1P in forum General Hardware Discussion
    Last Post: 03-13-2008, 08:23 PM
  2. Flash card bootable drive?
    By The Durango Kid in forum General Hardware Discussion
    Last Post: 03-16-2005, 09:20 AM
  3. The Os and The Car
    By SjLucky in forum Software & Software Development
    Last Post: 06-24-2004, 03:09 PM
  4. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 10:11 AM
  5. Which OS?
    By accord in forum Software & Software Development
    Last Post: 11-22-2001, 09:22 PM
