Results 21 to 30 of 35
Thread: CD/DVD drive - slot loading *and* USB?
  1. #21
    Variable Bitrate blurp's Avatar
    Sep 2003
    Hampshire, TN
    Quote Originally Posted by SamDude
    You thought right.... It was a feeble attempt.
    I was expecting the "Search/Google" replies when I started the thread - but sometimes the obvious is too close in your face for you to see what you really want...
    Oh, yeah, you got it alright!
    www.bradleyjacobs.com
    There is more stupidity than hydrogen in the universe, and it has a longer shelf life. -- Frank Zappa
  2. #22
    Constant Bitrate SamDude's Avatar
    London (UK)
    What I've gone for is a Pioneer slot loading IDE drive (the slim notebook version will come later when budget allows).
    If I use an IDE to USB converter, do I feed the power to the IDE drive directly from the Opus by chopping the power adapter that comes with the converter and diverting it to power feed that will also run the USB hub and Xenarc?
    (Just checking y'see...)
  3. #23
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
  4. #24
    London (UK)
    @muldrick
    The bit I need answered was:
    Not what I need to buy... (I've already got that sorted)
  5. #25
    Sep 2003
    Hampshire, TN
    I think I understand what you are asking, but I need a little clarification before I answer so that I don't give you bad info.
    Doyou mean that you want to cut the wall wart off the power adapter for the USB adapter and then just wire it up to the appropriate voltage on the Opus? I'm not sure what you mean about powering the Xenarc and the USB hub with it.
  6. #26
    London (UK)
    Quote Originally Posted by blurp
    Yup, that's exactly what I mean. By running a power feed from the Opus to the front of the car, I will split it by joining some molex connectors to the Xenarc, USB hub and the DVD drive.
    So, is it the same as wiring the power from the molex to the drive by chopping off the drive power connector and wiring them together?
  7. #27
    Sep 2003
    Hampshire, TN
    Yes, it *should* be the same. What is the voltage that the wall wart supplies to the USB adapter?
  8. #28
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    The USB adapter is almost certainly 5v (the bixnet/newegg enclosure certainly is) but the xenarc will need 12v. You'll have to get 4 core cable and exted the entire molex.
  9. #29
    Low Bitrate Twopoint's Avatar
    Jul 2004
    Kitsap WA USA
    most usb adapters use 5v about 2.5 amps but not all, you will need to double check what it says on the label
    out of the molex connectors you get:
    12v yellow
    gnd black
    gnd black
    5v red
    make sure you have enough room on the P/S (watt = volt x amp)
    '95 2 door Yukon
    in dash Xenarc 700TSV
    /w HP laptop
    into (installed)
    HU Alpine 9827 \ AMPS MRD-F540 + M301
    MB Quart 216\213 + DVC 10 Sub
    CarPC Pics
  10. #30
    Maximum Bitrate R32 JUhl's Avatar
    Nov 2004
    North Atlanta
    This link changed along with the price - it's now only $30!!!! WOOHOO!!!
    http://www.newegg.com/app/ViewProduc...145-157&depa=0
    NOW THE BIG QUESTION!!! Why does the FAQ section say this?:
    "Do not get a USB DVD player, just get a piece of Cat 5 split the IDE cable and extend it to the front of the car. Another option is to get a firewire expansion card for your PC and run a firewire cable to the front of your vehicle."
    http://www.mp3car.com/vbulletin/faq....ar_faq_media_a
    Is that possibly pre-2.0 USB advice? Am I misinterpreting the FAQ? Anyone know?
  1. Multiple drive USB or firewire enclosures?
    By robiewp in forum General Hardware Discussion
    Last Post: 03-15-2004, 05:32 PM
  2. External USB drive
    By mtmsol in forum General Hardware Discussion
    Last Post: 11-27-2001, 06:25 AM
  3. How about a BUSlink's Portable USB Hard drive ?
    By percyt2k in forum General Hardware Discussion
    Last Post: 05-25-2001, 09:47 PM
  4. Ever seen a front loading CD-ROM drive?
    By mjohnson in forum General Hardware Discussion
    Last Post: 02-23-2000, 06:32 AM
  5. Pioneer Slot Load DVD Drive Shock Resistant?
    By Bloomk in forum General Hardware Discussion
    Last Post: 01-15-2000, 05:46 AM
